Activity Forums Adobe After Effects Need comp frame rates to stay different in final comp
  • Need comp frame rates to stay different in final comp
    Posted by Matthew Wood on May 10, 2015 at 4:00 pm
    Hello. I have done it before, I just cannot remember how. There are dancers at 24fps and music at 30. But they sync up exactly how I want them to when I play them at these frame rates, in different media player windows.
    When either is adjusted to fit the other, it throws it all off.
    How can I keep them at these rates and render together? I know I can just combine them with other software and it will be fine, but I have to have some fx react to the audio
    I turned on the “preserve frame rate when nested” option on both comps but the audio comp still plays at the higher frame rate when I drop it into the main comp…. ????? Super frustrating
    Blood type O negative. I bleed zeros and ones
    I dabble on the desktop
    Shifted Leering, Any Perspective
    Shifting Literally All Perceptions
    SLAP
    Darby Edelen replied 11 years, 4 months ago 2 Members · 3 Replies
  • Matthew Wood
    May 10, 2015 at 4:21 pm
    I had done what you suggest, initially, and it just wasn’t working. It is an mp3, however, so I am going to attempt it with a wave, now, thanks
    SLAP
  • Matthew Wood
    May 10, 2015 at 4:36 pm
    — Ha, no, got it.. I put the 30 into the 24, initially. 24 into 30 as you suggested did it. You rock, man, Im stoked, thank you
    SLAP
  • Darby Edelen
    May 10, 2015 at 4:52 pm
    Audio files don’t have frames so there is no frame rate to speak of. Audio should play back at the same rate no matter what the frame rate of the composition is.
    Darby Edelen
