Activity Forums Blackmagic Design Need Color Bars with Pluge for Calibration through Deck Control
  • Need Color Bars with Pluge for Calibration through Deck Control
    Posted by Bizatch on April 16, 2006 at 10:40 pm
    Does anyone have color bars WITH pluge that I can run through Deck Control on a Mac? I don’t know how to calibrate my monitor with the bars that Blackmagic provides. I don’t have my actual deck hooked up through the system because I don’t have an RS-422 cable to hookup to the breakout cables that came with my Decklink HD Pro (Single Link).
    Adam
    Michael D replied 20 years, 4 months ago 3 Members · 5 Replies
  • Jeremy Garchow
    April 17, 2006 at 2:24 am
    Do you have FCP? If so, use their bars, or make an uncompressed self contained movie of the FCP bars and use that in the future.
    Or maybe these will help you?
    https://www.bobstevers.com/Articles/colorbar.html
    Jeremy
  • Bizatch
    April 17, 2006 at 3:00 am
    Jeremy,
    Thanks. The export from FCP worked. I was checking to see if I still get a green tint through the component portion of the Decklink HD Pro card. Tech Support told me to run bars through the Deck Control program to see if FCP was the problem.
    Unfortunately, I think my card is bad.
    Adam
  • Michael D
    April 17, 2006 at 5:50 am
    I had a DeckLink Pro card (SD) which exhibited the green tint when viewing files through the component out. I recently returned the card for replacement. Before removing the card I examined the luma, red, green, and blue histograms of a black and white file (captured with the card) using the software scopes in the After Effects plugin version of Color Finesse. After removing the card and the 5.5.1 drivers, I installed the 4.9 standalone codecs (available on the Blackmagic support page). I examined the histograms of the same file again. The histograms changed and the changes suggested a problem with the gain of the blue channel. (I haven
  • Bizatch
    April 17, 2006 at 3:40 pm
    Michael,
    Do you think this is a hardware problem or a software problem?
    Adam
  • Michael D
    April 17, 2006 at 6:26 pm
    Adam,
    Sorry, but I don
