Activity › Forums › Adobe Premiere Pro › Need clip transition effect ideas…
  • Need clip transition effect ideas…
    Posted by Accountneedsrealnameupdate on August 4, 2006 at 7:12 am
    I’m creating an action sports film that is basically a montage of clips. I need some ideas on how to transition from clip to clip. Most of the time there are no transition effects, but sometimes I use a fade to white (washout) effect, standard fade to black, tint change (fade to red, fade in from red). I need some new ideas that look good and are not annoying. What transition effects do you guys prefer in a montage type movie like this one?
    Hector Melendez replied 20 years, 1 month ago 2 Members · 1 Reply
  • Hector Melendez
    August 4, 2006 at 6:09 pm
    Look at sports news or similar to get an idea. I think also depends of the thriller music acompaining your project. A fast/slow motion also will help.
    DL Burguer transitions to have more choices. Note: not all works in PP2. I think the good ones are: 1,6,10,16,17,18,19,21,22,23. A bad one make PP not to start up. ( You have to go to Prog. files>Adobe> E.us and make a folder in there and throw in the transitions) If PP don’t start go deleting one by one while starting PP. (just what I did)
    Make a search to find “burguer transitions” it because I forgot the link. (Had from PP 1.5)
    Check Pinnacle Hollywood Effects too
