Activity › Forums › Apple Final Cut Pro Legacy › Need clarification from manual
  • Need clarification from manual
    Posted by Jason Brown on April 10, 2010 at 12:07 am
    I’m trying to use the range selection to delete multiple audio keyframes…I found in the manual on Page 925:
    To select a range of keyframes to modify
    Use the Range Selection tool to select a group of keyframes. You can now move, delete, or change the level of just those keyframes.
    So how do I delete them? I’ve done every combination of keystrokes/mouse drags I can think of…I can’t figure it out.
    -Jason
    Tom Brooks replied 16 years, 5 months ago 5 Members · 13 Replies
  • 13 Replies
  • Ron Pestes
    April 10, 2010 at 12:25 am
    The easiest way to delete keyframes is to click on them and drag them out of the timeline. Pooof, gone!
    Apple Certified Master Pro FCS 2
    Sony EX-3
    MacBook Pro
  • Jason Brown
    April 10, 2010 at 3:10 am
    So what about 140 keyframes? That’s a lot of “poof-gone’s”
    It’s in the manual…how do you do it?
  • Tom Brooks
    April 10, 2010 at 3:09 pm
    Looks like the manual is just plain wrong in this case, although I’m using FC 6, so results could be different in 7. As far as the “drag and poof” method goes, the Delete Point tool is faster and easier.
    If all the keyframes are within a single clip on the timeline I suppose you could razor blade on each side, remove attributes/audio levels, and then set a matching key frame on each end.
    If it spans many clips it would involve exporting and reimporting as a single clip. Personally, I wouldn’t consider that a workable solution.
  • Jason Brown
    April 10, 2010 at 3:48 pm
    The same language is on page 114 of version 6 manual.
    -Jason
  • Tom Brooks
    April 10, 2010 at 4:44 pm
    Yes, I found that, but, like you, I see no way to make it work. A search of previous posts on this forum retrieves a few other hits about the subject and confirms that the manual is baloney. Blatant false statements like that are rare, however. Hope for it in the next version of FCP. Moving a range of keyframes is similarly frustrating.
  • Kevin Monahan
    April 10, 2010 at 4:52 pm
  • Tom Brooks
    April 10, 2010 at 5:02 pm
    Done.
    – Tom
  • Jason Brown
    April 10, 2010 at 10:31 pm
    [Tom Brooks] “Moving a range of keyframes is similarly frustrating.”
    You do know about using the slip tool in the viewer to move the keyframes, right? Although it moves ALL keyframes…it could work for your specific application.
    And thanks for sending the feedback!
    Just got out of a color class with Robbie Carman at NAB! this week is going to be awesome…
    -Jason
  • Kevin Monahan
    April 10, 2010 at 10:35 pm
    I slip filters and motion keyframes in the filter and motion bars of Clip Keyframes. Just drag between the keyframes.
    Kevin Monahan
    60 Blu-ray Templates for Final Cut Studio 2009
    http://www.fcpworld.com
    Author – Motion Graphics and Effects in Final Cut Pro
  • Tom Brooks
    April 11, 2010 at 2:13 am
    I did not know about that. I work in isolation. It’s a thing of beauty. Thanks.
