Activity › Forums › Adobe Premiere Pro › Need blacker than black
  • Need blacker than black
    Posted by Cliff Stephenson on March 26, 2012 at 5:24 am
    Hey, so I’m delivering a clip and have been told that the black portions between my clips need to be at least -15mV (right now they were delivered at 0mV). I’m using the a black video clip generated in PP 5.5. I’ve added a level filter to the clip and raised the incoming BL to 25 and, for good measure, added a brightness/contrast filter and dropped the brightness down -35.
    Unfortunately there isn’t a scope that will show me blacker than black (or at least one I can find). Will adding these two filters drop the black level of this black clip down where they want it? It doesn’t have to be perfect, it just has to be lower than 0mV.
    David Speace replied 14 years, 6 months ago 4 Members · 6 Replies
  • Jeff Brown
    March 26, 2012 at 2:08 pm
    This is a strange request: digital files do not have anything that could be measured in millivolts, digital files are numbers.
    It sounds like they want a digital file that corresponds to SMPTE levels, where 15-235 corresponds to 0 and 100 IRE, but millivolts only appear in once your file is output into electronics of some sort.
    Some clarification is in order, methinks. Like: what is the file format they are asking for? And what video system (PAL/NTSC?)
    On the other hand, if you are delivering on tape, then mV are relevant.
    -jeff
  • Cliff Stephenson
    March 27, 2012 at 7:34 am
    It’s a picture in picture stream that was being laid off to HDCAM SR. Historically (I’ve done about 6 of these for Blu-ray) a straight 0mV black level has been fine, but this time they had a very specific spec that needed to be met (I assume to create an alpha for everything below a certain level of black). I adjusted the level filter as well as decreasing the brightness on the brightness/contrast filter and when we pulled it up on the scopes this morning it was registering sub 0, so it worked. I was just flying blind until then. Thanks for the help, though.
  • Jeff Brown
    March 27, 2012 at 3:41 pm
    Ah, tape! Then it makes sense. Glad it worked out OK. My guess is like yours: the superblack is used for alpha-channel-like needs.
    -jeff
  • Brian Mulligan
    March 28, 2012 at 8:43 pm
    WOW! I haven’t used super black since 1991. That’s old skool.
    Brian Mulligan
    Senior Editor – Autodesk Smoke
    WTHR-TV Indianapolis,IN, USA
    Twitter: @bkmeditor
  • Cliff Stephenson
    March 29, 2012 at 3:34 am
    That’s why I was so baffled. It isn’t a request I get everyday (or even every 5 years).
  • David Speace
    March 29, 2012 at 7:21 pm
    Yes… Premier has built-in scopes. Just open up the dropdown menu on the Program screen…
    Dave Speace
    Producer/Director/DP
    DZP Video
    Windows 7, 64 Bit, i7 8 Core, 16Gb Ram, GeForce 4800
