Activity Forums VEGAS Pro Need Batch Render Script that includes the name V10
  • Need Batch Render Script that includes the name V10
    Posted by Craig Scime on March 16, 2011 at 11:59 pm
    I had the script that Edward made for vegas 7, then tried to edit the current vegas 10 script but can’t save as a cs file and vegas won’t recognize the edited script….so I am wondering if any one has the script for vegas 10 that will batch render with the region name thanks craig
    John Rofrano replied 13 years, 4 months ago 3 Members · 5 Replies
  • John Rofrano
    March 17, 2011 at 2:50 pm
    [Craig Scime] “so I am wondering if any one has the script for vegas 10 that will batch render with the region name thanks craig”
    A quick search here at te COW would have uncovered this thread:
    batch rendering regions
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Craig Scime
    March 17, 2011 at 8:36 pm
    Hi John, I did do a quick search and found that post and tried (I searched on google, sony and vasst too)…and as I think I mentioned that windows 7 won’t allow me to edit the CS file in notepad. Once I make the changes from the post and save it…vegas doesn’t recognized in the script menu…hence my post out of frustration…I even have production assistant, thought that might help too…but it didn’t.
    I don’t understand why sony makes a batch render script that doesn’t include the region names. How do they think you would be able to organize your files?????
  • John Rofrano
    March 17, 2011 at 9:30 pm
    [Craig Scime] “I think I mentioned that windows 7 won’t allow me to edit the CS file in notepad”
    Sorry, I didn’t catch that. Under My Documents make a folder called “Vegas Script Menu”. Then copy the batch render script into this folder and change it’s name. Then edit with notepad and have Vegas refresh the scripts and it should show up.
    The problem is that Windows 7/Vista uses a new security model that doesn’t allow users to edit files in the “\Program Files” folder any more and this is where Sony keeps their scripts. Using the My Documents folder solves this.
    ~jr
  • Tim Mccallister
    May 12, 2013 at 9:37 pm
    I did all of the above, and no matter which script I use — the original Batch Render or my new Batch Render Region Name — I get the following error. Can you tell me what I’m doing wrong?
    System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation. —> System.ApplicationException: Render failed:
    file name: C:GLENNFilmmaking & ScriptsProjects – Video Film DVDFFSHD UprezProject FilesArchivedHD Intermediate test_QuickTime 7_Avid DNxHD 175-10-bit 1080p 23.976 MOS[0].mov
    Template: Avid DNxHD 175/10-bit 1080p 23.976 MOS
    at EntryPoint.DoRender(RenderArgs args)
    at EntryPoint.DoBatchRender(ArrayList selectedTemplates, String basePath, RenderMode renderMode)
    at EntryPoint.FromVegas(Vegas vegas)
    — End of inner exception stack trace —
    at System.RuntimeMethodHandle._InvokeMethodFast(Object target, Object[] arguments, SignatureStruct& sig, MethodAttributes methodAttributes, RuntimeTypeHandle typeOwner)
    at System.RuntimeMethodHandle.InvokeMethodFast(Object target, Object[] arguments, Signature sig, MethodAttributes methodAttributes, RuntimeTypeHandle typeOwner)
    at System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture, Boolean skipVisibilityChecks)
    at System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture)
    at Sony.Vegas.ScriptHost.ScriptManager.Run(Assembly asm, String className, String methodName)
    at Sony.Vegas.ScriptHost.CodeDomScriptManager.Run()
    at Sony.Vegas.ScriptHost.RunScript(Boolean fCompileOnly)
    Indie Filmmaker
  • John Rofrano
    May 13, 2013 at 11:59 am
    It looks like your code threw an exception and you didn’t catch it.
    Why don’t you use a proven render script like VASST Render Assistant? For $9.95 you don’t have to debug it and if it doesn’t work you get to have me fix it. 😉
    ~jr
