Activity Forums Adobe Premiere Pro Need audio guru’s advice on adobe premiere audio output
  • Need audio guru’s advice on adobe premiere audio output
    Posted by Spike Spiegel on November 23, 2015 at 4:23 pm
    Hi everyone! I’m trying to render out a 44 min project to a client’s spec and need your advice.
    The client wants channel 1: Full mix L Channel 2 Full mix R Channel 3: Mix minus (MDE only) L and 4: Mix minus (MDE only)R
    What i’ve done is rendered out 2 24 bit wav stereo files; one is the full mix stereo, the other is MDE only stereo.
    NOW, how do I tell premiere to give me 4 channels of audio with the configuration above? My tracks are prepared, the only issue i am having with now is at the exporting stage. Please advice. Much appreciated.
    Spike Spiegel replied 10 years, 9 months ago 2 Members · 2 Replies
  • Andy Edwards
    November 23, 2015 at 6:35 pm
    Spike,
    Have you used the search engine on this site or Youtube to answer your question? This type of question has been answered hundred of times and is available with a little work on your end.
    Depending on what version of CC you are using, you need to set up your sequences as Multichannel and assign all your audio track correctly before making the multichannel export.
    Take a look here:
    https://www.youtube.com/watch?v=VRKvBv7d1_8
    or search Youtube for:
    multichannel audio export in Premiere Pro
    Andy Edwards
  • Spike Spiegel
    November 27, 2015 at 4:11 am
    thanks that helped a lot!
