Activity › Forums › Adobe After Effects › Need Assistance Z tool Camera 3D space
  • Need Assistance Z tool Camera 3D space
    Posted by Greg Burke on February 26, 2013 at 3:46 am
    I have this shot where the AE 50mm Camera is suppose to Pan in (Z) into a picture turn around (Orbit tool) to another pic and Pan in Again However it wont Pan any further? Am I missing something? I should be able to move it in 3D space with out Limitations. Thanks in Advance.
    I wear many hats.
    http://www.gregburkepost.com
    Darby Edelen replied 13 years, 7 months ago 4 Members · 3 Replies
  • Vishesh Arora
    February 26, 2013 at 4:22 am
    Greg
    Yes, You are right. There is no limitation of keyframing any parameter.
    Can’t sat much without looking into your project and Timeline how you are moving your Camera in Z-Space.
    Though you can try parenting your camera to a 3D Null Object.
    Check this tutorial:
    https://www.videocopilot.net/tutorial/advanced_camera_tips/
    Vishesh Arora
    3D and Motion Graphics Artist
    Films Rajendra
    Blog:
    https://digieffects.wordpress.com
    2011 3D Demo Reel:
    https://www.youtube.com/watch?v=lHPgIJU_BR8
  • Paul Roper
    February 26, 2013 at 12:30 pm
    Try directly changing the rotation of the camera under its Transform section (just like you’d rotate any other layer) rather than using the orbit tool.
    – Paul
  • Darby Edelen
    February 26, 2013 at 6:17 pm
    If your camera is using a point of interest then it will only be able to orbit around that point. You might consider either manually animating the point of interest, or changing the camera to Auto Orient: Off and animating the orientation/rotation of the camera instead.
    Parenting the camera to a Null also allows for a lot more flexibility (note: animate the null instead of the camera unless you need to do something fancy).
    Darby Edelen
