Activity › Forums › Apple Final Cut Pro Legacy › need assistance with set up and import of media
  • need assistance with set up and import of media
    Posted by Jeani Oosthuyzen on January 9, 2013 at 8:13 am
    Hi there,
    I’m running final cut pro 7.0.3 and am trying to sort out my easy set up and system preferences to import my MOV files from my Canon SX220 HS but i can’t seem to find the right settings for my media to work. also,should i be bringing files in through cable directly from my camera or is it ok to import straight from my SD card?? Please help!
    Rafael Amador replied 13 years, 8 months ago 2 Members · 1 Reply
  • Rafael Amador
    January 9, 2013 at 9:25 am
    [Jeani Oosthuyzen] “I’m running final cut pro 7.0.3 and am trying to sort out my easy set up and system preferences to import my MOV files from my Canon SX220 HS but i can’t seem to find the right settings for my media to work. also,should i be bringing files in through cable directly from my camera or is it ok to import straight from my SD card?”
    That’s the way to go with tapeless formats.
    Use the Log&Transfer option.
    Before starting, you should have a look to this:
    https://library.creativecow.net/ross_shane/tapeless-workflow_fcp-7/1
    rafael
    http://www.nagavideo.com
