Need assistance with bringing files into Avid MC6.
I am trying to open several video files in Avid MC6 and I am getting errors.
First set of files are .MOD files shot on a JVC camcorder.
Second set of files are .MOD shot on a Panasonic camcorder.
Third is a file I received on a HD which is an .M2V file.I have tried using MPEGStreamclip to convert the files but it requires me to install QT Alternative 1.81 which I did, and MPEGStreamclip still doesn’t recognize the files. I managed to use AVS4U to convert a few of the files but it takes FOREVER. Is there an easier way to get these files into my Avid so I can begin working with them?
Using MediaInfo, here is an example of one of the files:
General
Complete name : C:UsersTriciaDesktopJosh Iniss video FootageYaw Exercise MOV001.MOD
Format : MPEG-PS
File size : 407 MiB
Duration : 11mn 8s
Overall bit rate mode : Variable
Overall bit rate : 5 105 KbpsVideo
Format : MPEG Video
Format version : Version 2
Format profile : Main@Main
Format settings, BVOP : Yes
Format settings, Matrix : Custom
Format settings, GOP : M=3, N=15
Duration : 11mn 8s
Bit rate mode : Variable
Bit rate : 4 748 Kbps
Maximum bit rate : 9 286 Kbps
Width : 720 pixels
Height : 480 pixels
Display aspect ratio : 16:9
Frame rate : 29.970 fps
Standard : NTSC
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Interlaced
Scan order : Top Field First
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.458
Stream size : 378 MiB (93%)
Color primaries : BT.601 NTSC
Transfer characteristics : BT.601
Matrix coefficients : BT.601Audio
ID : 189 (0xBD)-128 (0x80)
Format : AC-3
Format/Info : Audio Coding 3
Mode extension : CM (complete main)
Format settings, Endianness : Big
Muxing mode : DVD-Video
Duration : 11mn 8s
Bit rate mode : Constant
Bit rate : 256 Kbps
Channel(s) : 2 channels
Channel positions : Front: L R
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Delay relative to video : -66ms
Stream size : 20.4 MiB (5%)Menu
Any help would be much appreciated as I am fairly new to this and fresh out of ideas.
Thanks! 🙂
