Activity Forums Adobe After Effects Need assistance locating a plugin file inside of After Effects
  • Need assistance locating a plugin file inside of After Effects
    Posted by Gina Miller on September 27, 2017 at 3:37 pm
    Can anyone help? I am getting this After Effects error: “Couldn’t find main entry point for Picasso.plugin”. This error causes AE to crash at startup. I am using a Mac.
    I was having a difficult time finding info about it so I asked someone on Youtube the exact question above. This is as close to an answer as I got, he gave me a path to it’s location on a PC but I can’t seem to translate it to Mac. Please read the conversation we had below as it explains in more detail where I am at with this problem.
    He said:
    Sounds like an issue with the Picasso plugin – your best bet is to contact the company you got the plugin from :)
    I said:
    Before I try that I would like to find the actual plugin file in the AE program files so that I can try removing it to see if it works. I had another error for a different plugin and when I located it in my plugins folder and removed it, I did not have that error anymore. I can’t find this one (Picasso.plugin) in my plugins. I’d like to find out where it is so I can try removing it first. Do you remember who makes it? If I just google the plugin, I don’t find anything, makes me wonder if it’s a part of something rather than a plugin, unless you know different.
    He said:
    I can see a Picasso.aex plugin file in the usual spot – C:\Program Files\Adobe\Adobe After Effects CC 2017\Support Files\Required I’m on Windows though so you’d have to translate that to whatever path that is on a Mac
    I said:
    I do have a Mac, I looked in Applications/AdobeAfterEffects CS6/Plug-ins and I also looked in Macintosh HD/Library/Application Support/Adobe/Common/Plugins to no avail. Don’t see a required, do you know where that would be?
    –That’s where it left off, I haven’t heard back. Hoping some one here can help.
    Gina Miller replied 8 years, 10 months ago 3 Members · 13 Replies
  • 13 Replies
  • Gina Miller
    September 27, 2017 at 5:31 pm
    I’ve bought so many plugins over the years I must have but shouldn’t it be in the plugins folder then?
  • Gina Miller
    September 27, 2017 at 6:05 pm
    Do we know where it is in my program? I’d like to remove it and see if it solves my crashing error but I can not find it.
  • Cassius Marques
    There are two folders (at least in windows) that plugins get installed to. If you haven’t found it in the ordinary one (Program Files\Adobe\Adobe After Effects CC 2017\Support Files\Plug-ins) you can search in the common folder (Program Files\Adobe\Common\Plug-ins)
    Cassius Marques
    http://www.zapfilmes.com
  • Walter Soyka
    September 27, 2017 at 6:13 pm
    Picasso is the codename of Ae’s original ray-tracing 3D renderer (introduced in CS6).
    I think you should first try resetting your preferences (hold Command+Option+Shift while Ae is starting). If that doesn’t work, I’d suggest you uninstall and reinstall Ae.
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • Gina Miller
    September 27, 2017 at 6:35 pm
    Will this remove my plugins?
  • Gina Miller
    September 27, 2017 at 6:39 pm
    I would like to know this Cassius. I am on a Mac and I looked in Applications/AdobeAfterEffects CS6/Plug-ins and I also looked in Macintosh HD/Library/Application Support/Adobe/Common/Plugins to no avail.
    The person I spoke with on Youtube said “I can see a Picasso.aex plugin file in the usual spot – C:\Program Files\Adobe\Adobe After Effects CC 2017\Support Files\Required”.
    But he is on PC and I can’t find the Mac path to that and I would like to.
  • Walter Soyka
    September 27, 2017 at 6:51 pm
    It should not remove anything in the MediaCore plugin folder, but it might remove plugins in the main Ae application folder. You should back up first for sure!
    Walter Soyka
  • Gina Miller
    September 27, 2017 at 7:07 pm
    Walter I am looking at this video
    Is the Render Button drop down in the top right something that I could change? I can get into AE I just can’t open/or create a project or it will crash. I was wondering if this is something I can change or fix in AE, however I do not see that render drop down.
  • Gina Miller
    September 27, 2017 at 8:21 pm
    I thought that the After Affects CS 11.0.4 update might help if it was a 3D render problem because of reading about it here
    I downloaded the Mac update here
    But then I got an error (on top of the original missing Picasso error). It said “1 rendering plug-in was not found. (Standard 3D). The default rendering plug-in will be substitutied.”
    I don’t know if I had this native to CS6 (I don’t remember) but it seems like the update completely removed Ray Traced 3D. Evidence of this may be, after the update when I click New Composition I will get my Composition settings and in the Advanced tab I see Classic 3d in the drop down and nothing else. I should probably have the Ray Traced 3D option there right? By the way immediately after creating a new comp I still crash which is the same MO as before.
    Is there a way to get Ray Traced 3D back (I know it’s better)? Can I roll back the update?
    If my Picasso error and crashing is related to the Ray Tracing, is there a way to change these settings without deleted them? For example since I can open AE, in the settings there?
    I want fix this problem but now I’ve got 2 problems.
    As it stands now:
    I’d like to get Ray Traced 3D back from the update deletion (if that is the case) through a roll back.
    And I still need to figure out how to get rid of the Picasso error which is still crashing AE.
  • Walter Soyka
    September 27, 2017 at 8:29 pm
    I think that your installation has somehow become damaged. These are standard plugins that ship with After Effects. They have not been removed in later versions. The Ray-Tracing Renderer is different, not better, than Classic 3D.
    I’d suggest you backup your installation (specifically, third-party plugins, scripts, and any other presets that may be in the application folder), uninstall Ae completely, reboot, and reinstall Ae.
    Walter Soyka
