Activity › Forums › VEGAS Pro › Need Assistance ASAP please – Vegas Render for DVDA-DVD video stretched on TV
  • Need Assistance ASAP please – Vegas Render for DVDA-DVD video stretched on TV
    Posted by Chris Forsyth on June 15, 2011 at 5:38 pm
    Hey all,
    I need help with this – desperately.
    I have a simple 3 minute video – 1920×1080 @ 23.976 fps – finished in Vegas.
    I am rendering for DVD Architect to burn DVD’s.
    When I burn the DVD, and put it in the DVD player, and it comes up on my widescreen TV – the video is stretched wider – making people – and the picture – fat and stretched wide.
    Here’s what I’m doing:
    Vegas Render as follows:
    Render as Mainconcept Mpeg-2,
    Template: DVD Architect 24p NTSC Video Stream (output type DVD 720-480, framerate 23.976 + 2-3 pulldown, Aspect Ratio 16:9)
    Then, in DVD Architect:
    New Project / Single Movie / Disc Format = DVD / Project Video Format = Mpeg2 720X480 60i, 16:9 (NTSC).
    After burning, i drop it into the DVD player – hooked up to my widescreen TV, and it is stretched.
    Which of these settings am I wrong with.
    Nigel O’neill replied 15 years, 3 months ago 3 Members · 3 Replies
  • Douglas Spotted eagle
    June 15, 2011 at 7:21 pm
    based on your post, it would seem you didn’t use the widescreen template/
    Douglas Spotted Eagle
    VASST
    Certified Sony Vegas Trainer
    Aerial Camera/Instructor
  • Chris Forsyth
    June 15, 2011 at 7:43 pm
    Douglass –
    Can you clarify a little bit? Are you talking about the template in Vegas?
    I mis-posted in my original post. The Template I am using is:
    DVD Architect 24p NTSC Widescreen Video Stream
    Which has the following settings:
    Output Type: DVD
    720-480
    Frame Rate: 23.976 + 2-3 Pulldown
    16:9 Display
    Is this not the right template?
  • Nigel O’neill
    June 16, 2011 at 3:48 am
    Solved:
    https://forums.creativecow.net/readpost/24/931480
    My system specs: Intel i7 970, 12GB RAM, ASUS P6T, Vegas Pro 10 (x32/x64), Windows 7 x64 Ultimate, Vegas Production Assistant 1.0, VASST Ultimate S Pro 4.1, Neat Video Pro 2.6
