Activity › Forums › Creative Community Conversations › Need answers with 5d mark lll and fcpx
  • Need answers with 5d mark lll and fcpx
    Posted by Jonathan Lance on June 25, 2012 at 4:24 am
    I am a beginner and really need some advice.
    I am going to shoot a 2 hour 45 minute video of a play on a 5dmark lll
    here are the questions
    1) can I shoot at 1080, edit on fcpx and output it in 1080 hd on one dvd? Two dvds? or is it to long for any dvd format?
    2) If I export it as avchd can it fit on dvd? or is it too long? Maybe this question is the same as #1
    3) Should I shoot the video at 720? On the 5dmark lll the choices for frame rate at 720 is 50 or 60.
    I would like to thank you in advance. I have searched for hours and cannot seem to get an answer.
    John
    Viktor Kamenický replied 14 years, 3 months ago 10 Members · 15 Replies
  • 15 Replies
  • Dominic Deacon
    June 25, 2012 at 5:43 am
    1080 is high def and DVD is strictly standard def. And DVD doesn’t do AVCHD either. It’ll need to be converted once you’ve finished editing. 165 minutes is a lot to squeeze onto a DVD but it can be done if you don’t mind you’re image getting pretty compressed. Compressor or a similar program will have settings for best exporting whatever your file size is to DVD.
  • Jonathan Lance
    June 25, 2012 at 6:08 am
    how can I get HD to the end user? Blu ray?
  • Craig Seeman
    June 25, 2012 at 7:08 am
    Do they just want files for editing or compression?
    You can burn the to a Blu-Ray data discs which holds 25GB each. You may need a few discs 25GB discs or maybe 50GB disc.
    FCPX should be able to “share” to a Blu-ray disc as a simple screener.
  • Paul Jay
    June 25, 2012 at 8:00 am
    Bluray or Filebased
  • Mike Smith
    June 25, 2012 at 8:14 am
    Can you shoot video for that long on a 5D these days …?
  • Michael Gissing
    June 25, 2012 at 9:55 am
    The mk III with file spanning can shoot for 30 mins max. Not the right camera for shooting a play. Short shots, shallow depth of field, awkward viewfinder angle.
  • Rick Lang
    June 25, 2012 at 1:32 pm
    John:
    “I have searched for hours and cannot seem to get an answer.”
    Can you do a test where you shoot some moving subjects and verify if you can be successful? If the play has no intermissions or scene breaks, your camera may be the wrong choice for the job as it will stop continuous recording at 29′ 59″. And if DVD is the only delivery medium, it’s really best for durations between one and two hours for good quality. Hopefully you can rent a camera that can record SD rather than HD and record continuously for three hours.
    When I have recorded long events on tape, there’s always been an opportunity to swap in a new tape every hour but you may not have that opportunity unless you know there is time between acts to do it. If you use tapeless recording, you are going to have a problem with the file size limits you can record continuously. Your camera manual will describe those recording limits (29′ 59″).
    Rick Lang
    iMac 27” 2.8GHz i7 16GB
  • Jonathan Lance
    June 25, 2012 at 4:40 pm
    Thank you all for your help. I own one 5d mark iii and have access to another one, so I plan on having a two camera shoot. That way I can cover the camera that needs to be restarted. I have done some trial runs and it works rather well. There is no problem with over heating. There is also an intermission that will allow us to change cards etc.
    My main problem is what to shoot the video in. With the video about 165 min. my choices are limited. Here are my 5d mark lll choices of format
    1) 1920 x 1080 24 and 30 frames
    2) 1280 x 720 60 frames
    3) 640 x 480 30 frames
    I need to deliver the product on a dvd/bluray disk.
    I do not want to us 640 x 480.
    Can I shoot in 1920 x 1080 and deliver that or is it better to convert to 720?
    Should I shoot in 720 (1280 x 720) 60 frames and how would that work at normal speed.
    Sorry I am very confused and would take any suggestions you all may have.
    John
  • Rick Lang
    June 25, 2012 at 5:38 pm
    Having two identical cameras available with an adequate number of recording cards makes a difference to the feasibility of using the 5D Mark III. It may not be the best camera for the job as others have noted but if you’re determined to go with the 5D, then you can at least manage the recording time limitations. I would run both cameras but delay the start of the second camera about 15 minutes so you’ll be assured that you have time to load a new card into camera A while camera B is still rolling. And so on… May take a few cards but you can run a test to calculate how many cards you need depending upon the size of the card. You may find that information on the Internet as well if no one here tells you.
    Of course the size of the recording space also depends upon the rate you record. I’d go with the highest quality recording and certainly use 1920×1080 24 fps and possibly the ciné mode to do some grading in-camera if you like. Or you can grade it in FCPX or with BlackMagic Design’s Resolve Lite if you like.
    Do you have a Blu-Ray drive on your Mac and drivers? Do you have Blu-Ray authoring software so your Blu-Ray movie will have all the movie professional-looking bells and whistles? You should be fine as long as you know your client!s requirements and they are met by Blu-Ray. DVDs are not the way to go if the client will accept Blu-Ray.
    Rick Lang
  • Jonathan Lance
    June 25, 2012 at 5:57 pm
    Thank you Rick for all your help.
    I don’t have any bluray equipment or software at this point. What do you think of converting 1080 24 into 720 24? or is it just better to shoot it in 720 60 frames? will it fit onto a dual layer dvd?
    thanks
    John
