Activity Forums Cinematography Need advise for HD Camera for Documentary shooting
  • Need advise for HD Camera for Documentary shooting
    Posted by Meghna Damani on November 30, 2011 at 4:33 am
    I have been shooting my documentary feature on a panasonic dvx 100b. I have been advised to switch to HD. 1. what camera is most suitable for documentary shooting in HD – mid range with good sound and maneuverability in doc situations
    2. I have over 40 hrs of footage on dv (24p), will it be a problem mixing later?
    Appreciate inputs
    Meghna Damani replied 14 years, 9 months ago 2 Members · 2 Replies
  • Angelo Lorenzo
    December 2, 2011 at 1:11 am
    Honestly, I would strongly consider finishing the doc in Standard Def. I don’t know if you’re shooting in 16:9 or 4:4 (for all intents and purposes NTSC/PAL standard). If your existing footage is 4:3 you’ll need to add shadowboxes after it is up-resolved to HD (I assume you’d want your finished product to be delivered in HD if you switch to HD). Depending on how tightly you frame, a conversion to 16:9 may be impossible.
    Secondly, there is the general quality of your camera to consider. Unless you buy a camera near the same family as what you have, you should expect to do some color correction on footage from one camera to the other for a proper match.
    Thirdly, you may or may not have to upgrade your computer to accommodate the needed horsepower to process an HD post-production pipeline.
    As for camera recommendations, ENG style cameras are not my area of expertise, I’ve used the Panasonic HVX-200 (can be found cheaply used) and HPX-500 with no complaints as to their performance.
    Angelo Lorenzo
    https://filmsfor.us – Helping you sell your film online
    Watch Steve Job’s Spirit Inside The iPhone 4S
  • Meghna Damani
    December 4, 2011 at 11:54 pm
    Thank you Angelo,
    Appreciate you taking time out to respond. I’ve shot mostly in 16:9 and very inclined to stick with the DV, my only concerns are distribution as most networks will not touch DV, but then I could always upgrade in post, correct?
    Meghna
