Activity › Forums › Adobe After Effects › Need advice with Comp Settings
Posted by Justin Cordle on September 20, 2014 at 2:26 amI need to setup a comp with the following settings (see photo) Can’t seem to find the NTSC – CCIR 601/DV option.
Also can’t seem to find the 9:10 Pixel aspect ratio option.I am working in Adobe AE CC 2014
Any help would be very much appreciated!Justin C.
Justin Cordle replied 12 years ago 2 Members · 4 Replies -
Roland R. kahlenberg
September 20, 2014 at 4:14 amThe NTSC D1 preset should be what you’re looking for.
HTH
– RolandTypeGEMs – the Definitive Type Gizmo for AE
https://broadcastgems.com/typegems/Intensive mocha & AE Training in Singapore and Other Dangerous Locations
Adobe After Effects CC ACE/ACI
Imagineer Systems (mocha) Certified Instructorhttps://www.broadcastgems.com/mographintensity_shapestext/
Justin Cordle
September 20, 2014 at 4:19 amThank you so much! That helps me want to let you know 🙂
Do you have any insight into that 9.10 pixel aspect ratio? -
September 20, 2014 at 4:35 amIn AE, when youpick a preset, the pixel aspect ratio comes along for the ride. AE’s settings are accurate. The settings you provided shows a discrepancy – 720×486 is NTSC D1 while 720×480 is NTSC DV. Just select the NTSC D1 preset and you should be good to go.
Cheers
Justin Cordle
September 20, 2014 at 5:17 amThank you so much, I was so confused. I will make sure that those idiots that sent me the specs realize that they are wrong. You’ve been a huge help!
