Activity › Forums › Broadcasting › Need advice with 3/4 inch transfer to computer keeping quality up
  • Need advice with 3/4 inch transfer to computer keeping quality up
    Posted by David Andrews on January 10, 2019 at 8:57 pm
    I have a women who has a bunch of 3/4 in broadcast tapes. She want to transfer those to her computer. She actually has some kind of high end converter with YGB but it uses firewire. Is there a firewire convertible to HDMI out there …. She want to hold up the quality in the transfer. She has a sony deck … Any ideas.
    D
    Kevin Copeland replied 7 years, 8 months ago 3 Members · 2 Replies
  • Pat Horridge
    January 11, 2019 at 7:54 am
    Dump the fire wire solution. You are limiting the data rate at best at at worst are ending up with DV compression.
    Use a facility that can capture uncompressed ideally. Having a deck isn’t the same as using deck that’s mechanically sound and adjusted and electronically aligned.
    Pat Horridge
    Broadcast & Post Consultant, Trainer, Avid Certified Instructor
    Free online Tutorials at VET digital media academy online https://vimeo.com/channels/752951
    pat@vet.co.uk
  • Kevin Copeland
    January 24, 2019 at 8:11 pm
    The deck needs to be working good. Make sure the tape path and pinch rollers are clean. Clean the heads (but don’t break them off). And be sure to use a Time Base Corrector and input that into a capture card for your computer.
    It’s difficult to capture analog tape formats without a TBC.
    kc
