Activity Forums Audio Need advice SQN 5S mixer, 2 wireless lavs and a boom
  • Need advice SQN 5S mixer, 2 wireless lavs and a boom
    Posted by Thomas Yong on March 14, 2007 at 8:02 pm
    I have a gig tomorrow and I am going to be doing sound, and I am not too familiar with the SQN 5S field mixer.
    Most of the day there will only be two actors, so I will be running 2 wireless lavs on input ch1 and ch2 into the mixer and then feed the camera with the output ch1 and ch2 from the mixer.
    But there is a scene where there are two other speaking actors in addition to the two main cast where I will need to boom them. I was thinking on attaching the boom on input ch3 in the mixer.
    So my question is: How do I set up the SQN so I mix the two wireless lavs on output ch1 and run the boom to output ch2?
    Thomas
    Thomas Yong replied 19 years, 6 months ago 3 Members · 6 Replies
  • Edward Chick
    March 14, 2007 at 9:03 pm
    Should be a pan switch or knob for each input gain control; Pan the wireless on 1, boom on 2. Make sure Producer knows which will be which, either by verbal or write on the tape label. Relax, Record, Invoice:)
  • Edward Chick
    March 14, 2007 at 9:09 pm
    Need to clarify what I meant by panning on “1” I meant Left channel, and “2” Right channel.
  • Thomas Yong
    March 14, 2007 at 9:18 pm
    Thanks for your reply!!
    When I see the photos of the mixer. Here is a link: https://www.sqn.co.uk/5Sspec.html
    I don’t really see this kind of knob, but I do see on the back a switch for panning. Perhaps this is the one??
    Thomas
  • Edward Chick
    March 14, 2007 at 11:46 pm
    Sounds about right.
  • Will Salley
    March 15, 2007 at 9:14 pm
    There are switches on the right side of the unit to control output routing for each channel.
    System Info – G5/Dual 2 – 10.4.8 – QT v7.1.3 – 8GB ram – Radeon 9800Pro – External SATA Raid – Decklink Extreme – Wacom 6×8
  • Thomas Yong
    March 19, 2007 at 12:21 am
    Thank you guys for your advice. It helped a lot.
    I just wanted to let you know how it went down.
    I sat the camera audio levels to 20db for my Mixer tone.
    Of course when you are on a set with four talking actors, things changed in the last minute. For the the wide master shot, I decided to wire them all up using our old EV100 wireless which I believe used a Shoeps MK4. But regardless I mounted the mics on talent, I heard a lot of clothes noise, which was beyond use. I tried to use a little gaffa tape cup to protect the clothes interfere with the mic but nevertheless it didn’t work.
    So I would of course be interested in other microphones which are smaller and better for this kind of job. But perhaps it comes down to experience and of course have the right mics with you depending on the talents clothes. For example there was an actor with suit and tie, and his wireless mic was fine.
    When we punched in I simply discarded the wireless lavs and used a boom instead which gave great sound.
    In the first couple of shots, I couldn’t get the 2 camera XLR inputs to accept LINE, so I choose Mic which seemed to work. Of course two takes later I found out that the harness had switched the knob in the back of the SQN mixer to I/O or Mic out put. So I changed it back to LIne and then of course the camera took LINE.
    I must admit I am very disappointed with the wireless lavs. It all come down to the microphone perhaps and how experienced you are setting it on talent. But the sound I got was a nightmare.
    With the wireless lavs I did manage to use the back side of the SQN 5S to manage the mixing of what input goes out to what out put. So thanks for the posts all!!! But when I used the book, I cloned the mono signal into both Cameras XLR inputs.
    This is just meant as a little info from a not so experienced production sound mixer.
    Thanks again.
    Thomas
