Activity Forums Adobe Premiere Pro need advice please on File>Project Manager>transcode
  • need advice please on File>Project Manager>transcode
    Posted by Steve Zavo on February 6, 2020 at 8:57 pm
    I wanted to do that File>Project Manager>transcode to save space and consolidate and archive.
    The archived final material has DOUBLED in size, and each clip within is about 4X original size! Look, right there PPro is telling me I’ll wind up with 2.69 GB (below). Became 8.75 GB
    Below – what settings could change for the better? I only want the used material to transfer.
    Further below – I’m on ProRes 422 LT. I dont even know what those others are.
    Thank you !
    Todd Perchert replied 6 years, 7 months ago 3 Members · 5 Replies
  • Todd Perchert
    February 7, 2020 at 3:19 pm
    What is your original footage that you edited with? Image size and codec?
    ProRes LT may be less compressed than your original footage.
  • Steve Zavo
    February 7, 2020 at 9:24 pm
  • John Pale
    February 8, 2020 at 6:59 pm
    Without getting into the technical reasons why, the H.264 original would be a much smaller file size than the Apple ProRes 422 or LT copy.
  • Steve Zavo
    February 8, 2020 at 7:57 pm
    We are given many options to transcode and archive. Can you suggest what the efficient logical choices might be, please?
  • Todd Perchert
    February 10, 2020 at 7:50 pm
    I had a feeling it was h264 footage. As John said, and as you found out, ProRes will be a larger file. Your project was edited with the h264 original footage, right? If so, I would just keep that footage. I would not try to transcode it.
    TC
