Activity Forums Adobe After Effects need advice on which program to use
  • need advice on which program to use
    Posted by Lynne Margulies on December 24, 2007 at 10:06 pm
    I need to remove and add in new titles on a strip of film. There is movement under the existing titles, so I will need to draw/remove the titles frame by frame, and then add my new titles in their place. I’m very proficient in photoshop, and I’m wondering which program will best serve my needs for this task, After Effects or Shake? Or something else? I am using an intel-based MacBook Pro, and editing in Final Cut Pro 5.
    I.a. B. replied 18 years, 8 months ago 2 Members · 1 Reply
  • I.a. B.
    December 25, 2007 at 12:33 am
    well, i work very well in after effects, and i am learning shake right now, shake is VERY complex and there is alot to take on, and could yield the same results as after effects which is slightly easier, and defiantly wont disappoint you.
