Activity › Forums › Apple Final Cut Pro Legacy › Need advice on setting up drives
Posted by Bill Willins on July 21, 2009 at 1:01 amI’ve got two G-RAID Drives here , one is 500 GB ( pretty full) , the second is 2 TB ( new drive) . Both connect via FireWire 800. I’ve only got one FW800 port on this G5 dual 2 GHZ. My question is what is the best way to set up these drives. Plug one in FW800 , and then daisy chain the 2nd drive ? Or Plug one in FW800 port and the second in a free FW400 port. Thank you. Bill
Bill Willins replied 17 years, 2 months ago 4 Members · 8 Replies -
Rob Grauert
July 21, 2009 at 1:06 amI read that daisy chaining drives isn’t a good solution. It’s throughput is slow. What kind of media are you working with? I would put media on your 500GB drive that doesn’t need much speed and connect that through FW400
Robert J. Grauert, Jr.
http://www.robgrauert.com -
Bill Willins
July 21, 2009 at 1:11 amHi Robert , I’m just editing SD DVCAM material now. But I was just thinking that maybe I should transfer all the footage from 500GB drive to new 2 TB drive. I don’t want to lose all the FCP project links to video files… nervous about this.
Steve Eisen
July 21, 2009 at 1:48 amYou can always add another Firewire card inside your computer.
Steve Eisen
Eisen Video Productions
Board of Directors
Chicago Final Cut Pro Users Group -
Rob Grauert
July 21, 2009 at 1:52 amwell if your footage is all organized, when you reconnect one media file in FCP, it will recognize the other ones. I think you should transfer your footage to the 2TB drive, especially if your 500GB drive is almost full. The performance of drives starts to become compromised after the 50% point.
So I would transfer all the stuff from the 500GB drive to the 2TB and reconnect the media in FCP before cleaning out your 500GB drive. Then I would use the 500GB drive as a library. That’s what I do with my LaCie. I have an external that I store music on. Then when I want to use a song, I copy it to my project folder in my main drive.
Or you could use your 500GB drive for working in the field if you have a laptop. If/When you make the move to HD, you can offload P2 and SxS media to that drive.
All this making sense?
Bill Willins
July 21, 2009 at 2:22 amYes Robert, thanks..makes perfect sense. I am also considering installing an esata card in this older Mac G5 .. it only has PCI option .. not PCI-X. The 2 TB drive has an esata connection. That would be best , especially when I do some occasional stuff with HD footage.
John Fishback
July 21, 2009 at 2:01 pmYou should name the 2TB exactly the same as the 500GB and change the 500’s name. That way you may find FCP reconnects by itself without your manual intervention.
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor
ATTO ExpressSAS R380 RAID Adapter, PDE Enclosure with 8-drive 6TB RAID 5Final Cut Studio 2 (up to date)
Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
Bill Willins
July 21, 2009 at 2:21 pmHi John, That’s a cool idea, never thought of that option. thank you, Bill
