Activity Forums VEGAS Pro Need advice on raid 0 HD
  • Need advice on raid 0 HD
    Posted by Frenchie29 on March 21, 2007 at 3:36 pm
    Almost finished building my PC now I need to get the drives I was thinking Western Digital Caviar sata II 100gb for my C/ drive and 2 x500gb Caviar raid 0 for editing
    I have a Gigabyte 965p-DQ6 for mobo
    What you guys think??
    Anoni Moose replied 19 years, 6 months ago 5 Members · 8 Replies
  • 8 Replies
  • Anoni Moose
    March 21, 2007 at 7:20 pm
    Looks good to me. Great MB (that’s the one I use) but with the cheapness of drives nowdays, I’d perhaps make the ‘C’ drive a more normal price-optimized sized one (300~500G) and perhaps partition it to a smaller ‘C’ drive and a larger other partition to use for “other stuff”. Wouldn’t want power work areas in that other section because it’s still the boot drive (you’d use your RAID-0 array for that), but you’d have a lot of storage space for very little additional money. Ideally you’d have a third drive (not the RAID “single” drive or the boot physical disk) where your swap-file would go, but wouldn’t add one just for that.
  • Frenchie29
    March 22, 2007 at 2:59 am
    That’s a good I dea so maby 3x500gb 2 raid 0 for NLE and partition 1 for the C drive (what size would be good??) and the rest as another drive right??
  • Terje A. bergesen
    March 22, 2007 at 3:24 am
    Personally I wouldn’t go near WD. Serious quality issues for years now. I have had to replace more Caviar drives than any other drives I have ever used.
    Other than that your configuration seems reasonable.
    Terje A. Bergesen
  • Frenchie29
    March 22, 2007 at 4:48 am
    All my drives are maxtors but I heard that WD is better!!!
    What’s a good brand??
    How much space should I assign to my C drive??
    and what’s the difference between sata and sata II??
  • Adam Rose esq.
    March 22, 2007 at 11:40 am
    drive choice is pretty difficult, ie what works for one doesn’t work for another
    eg my WD have never failed, but bad experience with Hitachi / IBM a while back
    Some maxtors have a bad rep (eg series 9 IIRC) but the 10s are supposed to be good
    FWIW, my current drives of choice are Samsung. Good, reliable, quiet. I like.
    sata I vs sata II is virtually a non-issue. Lot of hullabaloo but doesn’t make much real world diffs.
    Personally, I prefer a C: of about 40-80GB. I don’t like too much stuff on C – used to make do with about 20GB but now a bit bigger, esp for catalog files for my digital juice stuff + google desktop indexes etc.
    Am busy building machine for self with E6600, 2GB, Asus P5B-E Plus and using a 160GB for system: 40 for C, about 100 for D (data) and small chunk for E (page file etc)
  • Janet Turner
    March 22, 2007 at 2:17 pm
    MP –
    I’m getting a new computer built and went with three 320 gig SATA Seagate drives. I have never had problems with Western Digital but I had several Maxtors fail. I don’t know what Maxtors are like now since I quit using them about four years ago.
    Grasshopper
  • Frenchie29
    March 22, 2007 at 3:49 pm
    I know I heard bad things about Maxtors too but never had a problem (knock on wood) but just too be on the safe side I won’t be going back with them
  • Anoni Moose
    March 22, 2007 at 9:56 pm
    Yes, that sounds like a good idea. Someone else mentioned 80G for the ‘C’
    drive, and that’s probably a good number.
    There’s a couple theories on how to do things. Some might have
    you have only a 20-30G partition and have ONLY the OS put there,
    then have another partition for the programs. Because programs
    always like to default installation to “C:\Program Files” and
    because I think it’s a very good idea to go along with defaults,
    I’d suggest a ‘C’ drive that includes all the installed
    programs that’s maybe 80~100G (which would include your swap file
    and your “System Restore” space). Then partition the rest as another
    disk. So you’d probably end up with C:, D: (raid), and E: (other partition
    of the C-disk). Although in XP at least, they can be changed (although
    I’d leave C as C). I put my RAID pair as “V” for my video disk (but
    then I’ve five or six drives).
    As far as brands are concerned, I currently favor Seagate drives. Maxtor
    is the only one that I’d consider one that I’ve had more trouble with
    overall. Maxtor was recently purchased by Seagate and the Maxtor brand
    name is being retained for use as Seagate’s low-end consumer line of disks.
    Hopefully the quality level is improving with new owner.
