Activity Forums Live Events & Streaming Need Advice on MPEG-2 Decoder Card
  • Need Advice on MPEG-2 Decoder Card
    Posted by Scott Bush on February 5, 2009 at 2:52 am
    Please advise if this is the wrong place to ask this or if a better forum may yield more results but…
    In March we have our annual client presentation where we show all of the work for the year, globally (TV commercials). Of course this year we need to cut huge financial corners yet put on a better show 😉
    Anyway we have traditionally used a Stradis MPEG-2 decoder card with a Windows PC playing out to a rear projector (one of a few, they are all about 4 or 5 years old, do not have model numbers handy). The vast majority of the material is archived in MPEG2 at 12Mbit/sec 4:2:0, SD. The issue is PAL/NTSC. The cards we have are required to be set before you begin playback, and it is not something that will be possible during the show. In the past we had enough money to simply have the PAL material converted to NTSC for the show at a post facility. This year we do not have the money to have it done or the resources to do it in-house.
    What I’m looking for is a new MPEG decoder that can switch NTSC/PAL on the fly, preferably with as little visible “cue” as possible. That, of course, can be worked around, but does such a card exist? I only need to do SD, although Would we perhaps be better off using a media PC thus skirting the entire issue?
    Scott
    Walter Soyka replied 17 years, 6 months ago 4 Members · 17 Replies
  • 17 Replies
  • Walter Soyka
    February 5, 2009 at 8:44 pm
    Hi Scott,
    If your projectors will accept a VGA input, you could play back from a standard modern PC or Mac with an MPEG2 software codec installed and dodge the format issue entirely.
    I always recommend a live backup for computer-based playback, so that just in case your playback system crashes while it’s live, you’ve got a second source to switch to.
    Walter Soyka, Principal
    Keen Live, Inc.
    Presentation, Motion Graphics & Widescreen Design
    RenderBreak: A Blog on Innovation in Production
  • Dale Doebert
    February 6, 2009 at 2:59 pm
    Maybe a product like a Grass Valley Turbo. You could load the files on the box and let them it convert for you.
    Much easier playback and user functions then a PC.
    Not entirely sure what it would do to PAL but I’m sure it could convert it.
    Dale Doebert
    dale@tiltmedia.com
    Video and Event Producer
    Tilt Media Inc.
  • Scott Bush
    February 6, 2009 at 3:48 pm
    Thanks for the suggestions. Dale, problem with your solution is that we don’t want to convert. We need the quality to stay PERFECT (very picky client – with a very good eye!). When we’ve had the PAL stuff done in the past, we have had to order DigiBeta masters first, then make the NTSC MPEGs from that. So converting MPEG-2 to anything except uncompressed or lossless (not practical for obvious reasons) would be unacceptable.
    I need to be able to play they without converting – is there such a card that can switch standards seamlessly? Or would a computer be my best bet? If I use a computer, though, I guess I’d need a second monitor to control it? They do NOT want to see someone operating windows – they want a clean screen with commercials only. Any distractions like glitches or someone working a mouse would not be ok.
    I’m waiting for a call back from Stradis to see if they have something.
    Thank again for all suggestions.
    Scott
  • Walter Soyka
    February 6, 2009 at 5:58 pm
    The Turbo is a great suggestion — it’s a PC-based DDR that uses MPEG2 internally anyway. It has a separate interface for the operator. You might want to check in with a local staging company, as they would be able to give you guidance on the multi-format issue.
    Keen Live, Inc.
  • Scott Bush
    February 6, 2009 at 6:31 pm
    I admit I didn’t do a ton of research but from what I see that Grass Valley box costs near $10,000. Is that accurate? If so, that is way over budget. We’re looking for something in the $2000 or less range. Honestly we’d go straight from a PC via VGA first.
    I know this is quite a request – believe me I know first hand 🙂 Thanks for all the input!
    Scott
  • Walter Soyka
    February 7, 2009 at 9:07 pm
    Hi Scott,
    The Turbo does list at $10k, but if this is an event (rather than something ongoing), you can rent one well within your budget from a staging company for the occasion.
    Keen Live, Inc.
  • Thomas Leong
    February 8, 2009 at 10:09 am
    Here’s my 2 cents –
    A clean XP PC loaded with AvStumpfl Wings Platinum, fitted with a mid-range dual head graphics card, and connect one output to a monitor and the other to your projector. Set the graphics card outputs to span the monitors rather than clone mode. Load up Wings, and drag its Timeline to the monitor output, and the Preview Window to the Projector output. Double-click on the Preview Window and it becomes full-screen (no windows, no borders except for black depending on the screen format of your MPEG-2 videos, etc). All your videos will now play full-screen on that output while your controller Timeline (for pause, stop, play controls) are on the monitor output. The MPEG-2 codec used is from Mainconcept.
    You can download the demo version at avstumpfl.com. In fact try the Basic Version, which is free-ware (needs registration for continued usage, but still free). The Basic version allows one video track and that might suffice. If not, read the Help Files for comparison with the other versions, and perhaps buy the USB dongle key for one of the next 2 versions up…AFAIK, they are below your budget. Only the Multi-screen version is above your budget…and you do not need that.
    Thomas Leong
  • Scott Bush
    February 8, 2009 at 7:45 pm
    Many thanks, Thomas – I will look into that.
    Scott
  • Scott Bush
    February 8, 2009 at 7:47 pm
    Walter, thanks,
    I will look into that, but I know they’d rather have something we can use in the future. Besides that, it looks like non-video-pros will be operating this stuff, so the more simple I can keep it the better (I will be busy editing and not able to help with the actual show – only prep).
    Still worth looking at, though. Thanks.
    Scott
  • Scott Bush
    February 10, 2009 at 8:35 pm
    Thanks everyone for your patience 🙂
    So the more I look into this the more it looks like going straight out from the computer (rather than an mpeg card) will be my best bet.
    is there anything similar to what Thomas recommended (AvStumpfl Wings Platinum) on the mac side? we may end up just going with VLC, but something with some nicer options would be nice. Or perhaps other ooptins for windows? The person who will be running the show is “more comfortable with macs” but isn’t against using windows… so if there is something on the mac end that may fit the bill better.
    scott
