Activity › Forums › Audio › Need advice on fixing awful interview audio with iZotope RX 6
  • Need advice on fixing awful interview audio with iZotope RX 6
    Posted by Erik Rosenbluh on May 8, 2017 at 3:58 pm
    I was given an interview that was recorded, to put it mildly, gawdawful. I was wondering if there was a way to make it audible? I played with iZotope RX 6 a little, but I’m no sound mixer. I’m hoping someone has some suggestions, or can at least tell me it’s a lost cause.
    Original:
    https://youtu.be/JAQFCcoAiz4
    My attempt at cleaning it up:
    https://youtu.be/YYWVBehK8SU
    Thanks in advance.
    Chris Wright replied 9 years, 4 months ago 2 Members · 3 Replies
  • Chris Wright
    May 9, 2017 at 4:01 pm
    ill try it if you post a download link. i’d first do a de-clip, de-reverb, then a de-noise, in that order. then I’d use leveler freqs. or I’d try noise reduction in audition with learn sound model.
    then enhance vocal range raising 95hz 2.5 dB Q 2 width, and 972 hz 4.5dB Q2 and 1306 Hz 4 dB 2Q
    then multiband compressor
    finally
    match loudness ITU-R BS.1770-3 -24lufs for correct audio levels
  • Erik Rosenbluh
    May 9, 2017 at 8:42 pm
    Which setting would I use to enhance the vocal range raising 95hz 2.5 dB Q 2 width etc?
    But if you’d like to give it the old college try, here’s a link to an AIFF output.
    https://www.dropbox.com/sh/lp2nk3mdq8o8lnz/AACzpVTdCPwT-ra9eX3PsmQ7a?dl=0
    Erik
  • Chris Wright
    May 10, 2017 at 4:38 pm
    its leveler. do you have the advanced version? it comes with vocal enhancer as well.
    what happens when you try my steps? I need to update my rx! i just need 30 sec. audio. 329mb?
