Activity › Forums › Compression Techniques › need advice on cleaning up stray pixels and using multiple codecs
  • need advice on cleaning up stray pixels and using multiple codecs
    Posted by Roli Rivelino on March 8, 2010 at 9:29 am
    I read a blog that suggested that cleaning up stray pixels and using filters to generally clean up the video, possibly using Quicktime? Also using different codecs for different parts of the video.
    The problem is, it didn’t really explain how to do that, so could someone please point me in the right direction on this one?
    Many thanks
    aka Newbie Wan Kenewbie. “The young Newbie, is now a Padawon.”
    System
    Mac Pro 2.8Gb quad core
    8Gb RAM
    1x 320Gb 7200 hardrive
    1x 1Tb 7200 hardrive
    Nvidia Geforce 8800 512mb Graphics card
    1x 1Tb external WD ‘My Book’ eSata
    Equipment
    Panasonic AG-HVX 200
    Firestore FS-100
    Roli Rivelino replied 16 years, 6 months ago 2 Members · 8 Replies
  • 8 Replies
  • Daniel Low
    March 8, 2010 at 11:27 am
    Temporal noise reduction filters can cleanup stray pixels but take quite some time to process.
    Quicktime movies can contain any number of different codecs within the same .mov.
    The question is, what are you trying to achieve?
    Sent from my iPad Nano.
  • Roli Rivelino
    March 8, 2010 at 12:18 pm
    Thanks for your answer Daniel, just a quick one, where would I find the temporal noise reduction filters, would that be in the filter section of the particular codec I’m using within compressor?
    To answer your question I’m trying to achieve the best quality non lossy video I can, my video contains quite a few static or slow moving shots combined with some fast energetic dancing, as I understand it may be better to encode the dancing bits differently.
    On this one time is not such a big issue.
    System
    8Gb RAM
    Equipment
    Firestore FS-100
  • Daniel Low
    March 8, 2010 at 12:42 pm
    Try using the Noise Removal filter in compressor, found in the filters section of the Inspector.
    [Roli Rivelino] “as I understand it may be better to encode the dancing bits differently. “
    Personally I’d just a variable bit rate (VBR). Far less hassle than what you are proposing. Or at the least stick to one codec and encode at different settings if the scenes vary that much.
  • Roli Rivelino
    March 8, 2010 at 12:50 pm
    Ah great thanks, I’ll try using the VBR, but at some point I’d like to try what you propose by sticking to the same codec but at different settings.
    How would I do this, would I add in and out points?
    I’ve never done anything in compressor but mess around with the settings and encode the entire video, so I’m not sure how to do all of that extra stuff.
    System
    8Gb RAM
    Equipment
    Firestore FS-100
  • Daniel Low
    March 8, 2010 at 12:57 pm
    [Roli Rivelino] “How would I do this, would I add in and out points? “
    Sadly not possible.
    You encode each part separately and then ‘stitch’ them together in Quicktime Pro.
  • Roli Rivelino
    March 8, 2010 at 1:36 pm
    OK last question (promise!) encoding separately is obvious, but how do I stitch together in QT pro?
    System
    8Gb RAM
    Equipment
    Firestore FS-100
  • Daniel Low
    March 8, 2010 at 2:24 pm
    Very simply. Just copy and paste the sections together and then save as a new self-contained movie.
  • Roli Rivelino
    March 8, 2010 at 3:28 pm
    Ah simple, thank you.
    System
    8Gb RAM
    Equipment
    Firestore FS-100
