Activity › Forums › Apple Final Cut Pro Legacy › Need Advice: How to speed Export
Posted by Ned Miller on November 8, 2012 at 3:26 pmI am working in 6 on a Mac Pro Quad Core Intel Xeon with 2.8 GHz and it’s taking FOREVER to export a low rez video of about 29 minutes, perhaps because I have the time code reader filter on it. I have all other apps turned off and had restarted.
I have Google searched and tried a zillion settings, I’d call myself an intermediate editor. I have done many five second tests using QT Conversion. It is OK if the video is low quality because it is just for the client to approve sound bites, in fact I’m thinking of sending audio only but that doesn’t seem quite professional.
Any advice? Or is this just necessary when dealing with a 29 minute video that has a time code reader filter?
Ned Miller
Chicago Videographer
http://www.nedmiller.com
www,bizvideo.comMichael Gissing replied 13 years, 10 months ago 6 Members · 12 Replies -
Ned Miller
November 8, 2012 at 3:41 pmThanks Dave,
It says 4 hours. I can’t get into my codec settings until it is done since exporting locks me out. I tried DV/DVCPRO because a YT tutorial suggested that, it didn’t help so I am still doing H264. I put quality to medium, made audio mono, closed apps, reduced size to 320×180 (don’t know if reducing the size helps), so I did all the usual suspects. I am thinking it’s just the nature of the beast of a 29 minute sequence that has the TC reader overlayed on it.
I could use Proxy Mill, the codec of the camera was AVCcam from a Panasonic AF100 but my understanding is once I bring it into FCP it is then OK.
Thank you
Ned Miller
www,bizvideo.com -
Ned Miller
November 8, 2012 at 3:56 pmThanks. I think I’ll try Proxy Mill for my low rez client approval files.
Ned Miller
www,bizvideo.com -
Steve Eisen
November 8, 2012 at 5:34 pmNed
There are a few options that can speed up h.264 encodes. The least expensive is the Elgato Turbo .264 HD. It looks like a thumb drive. Quality and speed are ok.
The next option is from Matrox. PCIe Compress HD Card or the Max option in their MXO2 io boxes. I have the Compress HD card in my Mac Pro and can not say anything bad about it. I bought it the day it first shipped. It has saved me HOURS of time encoding and the quality is spectacular. Did I mention encode time are Super Fast?
You do not need to add the Timecode Generator filter in FCP. You can add the timecode in Compressor using the timecode generator filter. Click on the filter tab in the inspector and scroll down to Timecode Generator. From there you have tons of options to change font, color and location.
Steve Eisen
Eisen Video Productions
Vice President
Chicago Creative Pro Users Group -
Ned Miller
November 8, 2012 at 6:21 pmGreat! Elgato is only $80 on Amazon. Thanks for the tip, will buy it for next time.
Ned Miller
www,bizvideo.com -
Chris Tompkins
November 8, 2012 at 8:59 pmYour comp is old and slow.
The 2011 iMac will export the same video in 1/4 the time.Chris Tompkins
Video Atlanta LLC -
Ned Miller
November 8, 2012 at 9:02 pmHi Chris,
I bought my tower in June of 2008. Are you saying I can get better results with the 2011 iMac? Can I hook up my two large monitors to it? What would you suggest I buy. Really appreciate your advice.
Ned Miller
www,bizvideo.com -
Chris Tompkins
November 8, 2012 at 9:07 pmThe iMac screen is 27″ Nice and big, you’ll love it.
Secondly, Yes, with a TB connection you can have a 2 monitor setup.TB Screens are not cheap. I have a TB to DVI connector feeding a second/smaller monitor. Works fine for now.
Chris Tompkins
Video Atlanta LLC -
Ned Miller
November 8, 2012 at 9:18 pmHi Chris,
What’s a TB connection? I have two Cinema Display monitors presently, since the iMac has such a large one then I figure I will just need one of my present ones. Can you please tell me what I should do in terms of upgrades? I don’t do a lot of heavy graphics, mainly documentaries and corporate videos. Between the $1300 and $1500 is there a big speed difference for the kind of work I do?
$1300
2.7GHz
2.7GHz quad-core Intel Core i5 processor (Turbo Boost up to 3.2GHz) with 6MB L3 cache$1500
2.9GHz
2.9GHz quad-core Intel Core i5 processor (Turbo Boost up to 3.6GHz) with 6MB L3 cache
Configurable to 3.1GHz quad-core Intel Core i7 (Turbo Boost up to 3.9GHz).I can’t believe they are so cheap. I think I spent close to $4000 four years ago.
Ned Miller
www,bizvideo.com -
Chris Tompkins
November 8, 2012 at 10:17 pmYa, iMacs are cheaper then Desktop PowerMacs for sure.
Be aware there are brand new, better iMacs coming out THIS YEAR.
With comps. it’s always the same rule: buy the most powerful you can afford at the time. You are buying the longest shelf-life possible.
TB=ThunderBolt
Chris Tompkins
Video Atlanta LLC -
Ken Mitchell
November 9, 2012 at 12:58 amI have the Matrox Compress HD card. It will do H264 in real time. Very good quality. Options. Bought it on ebay for $100.
