Activity Forums Adobe After Effects Need a way to align photos in AE with ability add more later
  • Need a way to align photos in AE with ability add more later
    Posted by John Weaver on November 27, 2017 at 5:40 am
    I’m shooting progression photos for a large construction project and would like to a streamlined process for aligning the photos so they can be shown in a slideshow/video. The photos will dissolve above previous photos revealing the progress. Even better would be a template of some kind like the photos are printed out and appearing over previous photos on a table or something.
    Previously, I’ve aligned the photos in Photoshop, then imported them into Premiere & added slow zoom out to give life to the slideshow. However, I would have to do it all over again each time I want to add a new photo to the progression.
    I’m hoping this can be done in After Effects or another Adobe program so that I can continue to build the slideshow as the construction project goes along.
    Can anyone tell me ideas on the best way to go about this?
    John Weaver replied 8 years, 9 months ago 2 Members · 2 Replies
  • Mark Whitney
    November 27, 2017 at 2:46 pm
    Probably other solutions out there but you might take a look at this:
    https://aescripts.com/easy-slide-show/
  • John Weaver
    November 28, 2017 at 12:05 am
    Your point is valid, but mostly inapplicable in my situation. I may not have been clear in the original post, but I’m taking aerial photos as a commercial drone pilot. This isn’t a situation that warrants exact placement from shoot to shoot.
    All the photos have been built into a flight software so they are taken from the same GPS coordinates each time. However, many variables like wind, compass calibration, launch point (can change at times), and margin of error means that the photos will never be in the exact same place every time.
    I thought through all of this before I began the project. But to begin with, the company wanted multiple extra angles so they could choose from their favorites. It wasn’t until the 3rd shoot or so that we could actually set GPS points to limit variables in future photos. That means some of the earliest photos were from different heights, slightly different angles, and even different proximity. I’ve learned a lot for future projects to avoid the struggles I’m facing with alignment now.
    Unfortunately, there is no going back in time unless you’ve got another helpful idea on that. I’m looking for a solution that fits my current situation with the first 3 of 7 (so far) progress shoots being in slightly different positions. I can continue to use the method I outlined, but there has to be better ways.
