Activity Forums Adobe After Effects Need a hand understanding linear workflow
  • Need a hand understanding linear workflow
    Posted by Martin Pedraza on February 1, 2019 at 7:15 pm
    So, lately i’ve been coming across more projects that require the use of linear footage, and it’s always this alchemic black box I stumble around, even after reading documentation.
    I’m looking for some enlightment, in the layman-est way possible.
    Here are the details of the current project: I’m receiving some adobe link AEPs, to do some compositing work on, from the resident editor. They are XMFs produced by a pair of Sony FS5 and FS7. The footage i receive, if I understand correctly, is S-log 2.
    Here begin my doubts, then:
    I believe, In order to do my compositing correctly, I need to setup the colorspace in such a way that I don’t perceive it as gray and washed out. Then, I need to output a .mov back for the editor, which is in itself, linear again. Afterwards, the final strip goes to the colorist, and that would be the endpoint.
    -What should be the colorspace I need to use in AE? Currently it’s like this:
    -With the colorspace applied I suspect is the correct one, it looks like this:
    Which looks better, but still a bit flat. Is that enough? Am I missing a LUT or something?
    And finally, and probably most importantly:
    -What should be the output settings, so that the editor gets a flat, colorist friendly result after i’ve done my comp work? Is this it?
    I’ve seen some documentation videos on linear workflow, but I keep getting lost in this, got too used to working on regular sRGB for TV too long. Any help will be appreciated. Cheers!
    Martin Pedraza replied 7 years, 7 months ago 1 Member · 0 Replies
  • 0 Replies
