Activity › Forums › Adobe Premiere Pro › Need a crisp clear output
  • Need a crisp clear output
    Posted by Rajesh Kumaresh on June 10, 2010 at 6:22 am
    Hi all…
    I have been trying to export this video out of Adobe Premiere pro cs4.
    Its an animated video made in after effects out of which i have rendered the shots (.avi) and edited them in adobe premiere.
    My final export is giving me a lot of loss in quality..its pixellated..non crisp diagonals.. and somehow there is this weird shake in the output video.
    I have tried exporting it in
    DVpal as an avi
    an mpeg2
    a quicktime export with photo-jpeg
    but its still the same.
    How can i maintain the quality of the avi’s which i have exported out of aftereffects ?
    Cant i get the same quality after i re-edit them in premiere ?
    A link to the video is
    https://www.vimeo.com/6303775
    This quality too is much worse than the output of the un-edited shots from aftereffects..
    pls help.
    I need the output for television viewing in Croatia, Europe.Its going to be a music video. Any know-how about the formats there would be helpful too.
    Thanks.
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
    Rajesh Kumaresh replied 16 years, 3 months ago 2 Members · 4 Replies
  • Jeff Brown
    June 10, 2010 at 11:41 am
    How are you exporting out of AfterEffects? What codec? (AVI is not a codec…). What are your project settings in AfterEffects (pixel size, aspect ratio, and frame rate)?
    -jeff
  • Rajesh Kumaresh
    June 10, 2010 at 2:22 pm
    Hi jeff,
    I have rendered the videos as
    Video for Windows
    768 X 576
    Pixel aspect ratio D1/DV NTSC (0.91)
    Frame rate 25 fps (in composition)
    Though surprisingly the rendered video properties, windows shows 12 fps.
    Also m really sorry jeff but i cant remember the video codec. it was almost an year back that i made this. Is there any way of finding the codec of a rendered video ?
    Its about 8.38 mb for a 5 second file. Can u judge it by that ?
    Regards
    R K
  • Jeff Brown
    June 11, 2010 at 4:27 pm
    Download GSpot, a very handy free utility that will give you all sorts of info about a media file.
    Your problem may stem from compression->re-compression.
    -Jeff
  • Rajesh Kumaresh
    June 16, 2010 at 9:18 am
    Hi jeff..
    sorry for the late reply…it appears that ‘buggy’ cs4 was givin me a lot of problems..i installed premiere pro2
    worked like a charm..
    thanks for your time..
    RK
