Activity Forums Adobe After Effects Need a codec with alpha support+HD
  • Need a codec with alpha support+HD
    Posted by Eran Solomon on October 13, 2013 at 10:05 am
    Hey everyone,
    I have a certain system that can only accept files under 10mb, I have a 10 second clip with alpha, on HD resolution (1920×500), its a lower third.
    Anyone have any ideas on this? with “Animation” quicktime preset i get a file which is over 150mb.
    Thanks in advance!
    Hope Holmesby replied 12 years, 10 months ago 5 Members · 6 Replies
  • Tudor “ted” jelescu
    October 13, 2013 at 10:32 am
    Can that “certain system” assign alpha to a clip from a matte render (black & white)? It sounds like it should based on the 10mb limitation.
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Walter Soyka
    October 14, 2013 at 2:44 pm
    What is the system? What codecs does it support?
    Speaking generally, some codecs which support HD and alpha include QuickTime PNG, DNxHD, and ProRes 4444.
    Walter Soyka
  • Eran Solomon
    October 15, 2013 at 7:17 am
    Thanks for the reply everyone.
    i don’t have specific info on the system since its used in a different facility all together.
    what I can tell you is that its a lower third, animated. so its wide (1080) but only 500px high (including the upper transparent part)
    What i do know is that the files that are imported into the system should not be more than 10mb.
    no matter what codec i tried – i only get it out at around 150mb.
    Is this even possible?
  • Juan Manuel
    October 17, 2013 at 3:19 pm
    JPEG2000 might do it, but the file size restriction is odd. Trying to get it under 10 MB might sacrifice too much quality.
  • Hope Holmesby
    November 4, 2013 at 10:48 pm
    hi guys, thanks for all your help always
    …just wondering…
    if you have a flame movie w a black bkg. can you render it w rgb+alpha and get a movie w the black bgk of the movie changed to alpha?
    or
    do you have to apply an unmult or screen to the layer then render it rgb+alpha , with the comp bkg blk, to actually get alpha?
    thanks so much.
    __________________________________________________
    Life is here to enjoy.
    iMac 3.5 GHz Intel Core i7, 2TB; Mac OS 10.6.8, 16 GB RAM; 2 La Cie external HDs 1 TB each; After Effects CS5.5; Sound Track Pro 3.0.1; Final Cut Pro 7.0.3; Compressor 3.5.3
  • Hope Holmesby
    November 4, 2013 at 11:13 pm
    hi…just tested the:
    png, jpg 2000 and apple prores 4444
    the jpg is the smallest file, almost 5 times…
    2MB vs 8.9MB
    the prores warned that colors would be reduced.
    the jpg did not, however since it is a smaller file, probably did reduce the colors, but it is not showing.
    however, in the new mavericks OS for mac, if you use jpg2000 or png, you will not get a video preview, nor w an animation codec.
    only the apple prores 4444 allows that, until someone comes up w a fix for that.
    very sad…
