Activity › Forums › Apple Final Cut Pro Legacy › Need 8-port sata raid controller card suggestions
Posted by Ian Dillon on May 30, 2011 at 12:01 amI was very pleased with my 8 drive SATA RAID 0 tower until my Power Mac died so I am stuck with a useless 8-port PCI-X Sonnet Tempo-X eSATA RAID controller card.
So now I have purchased a used Mac Pro which is PCI-E and need suggestions on how I can get my 8 drive tower back up and running. So far I haven’t had much success finding any 8 port PCI-E SATA cards. Any suggestions?
Thanks in advance!
Ian.Playroom Creative
We are an Orange County Video Production and Marketing company.
http://www.PlayroomCreative.comJohn Pale replied 15 years, 3 months ago 5 Members · 7 Replies -
Jerry Hofmann
May 30, 2011 at 1:09 pmAny PCIe card should work. CalDigit’s card is a good one I know. Doesn’t matter how many drives you’ve got in the array.. only need one port for it AFAIK.
https://www.CalDigit.com/FASTA-4e.asp
Jerry
Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
Current DVD:
https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX – Cinema Displays I have a 22″ that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
John Pale
May 30, 2011 at 3:13 pmJerry,
It sounds like he is not using a port multiplier chassis and has separate connections for each drive in the array.
These are much faster than the more common port multiplier units. I have a Sonnet 4 port card for this purpose, but I believe they do not have an 8 port model.I think Highpoint makes a RocketRaid 8 port model.
Ian Dillon
May 30, 2011 at 8:15 pmYes. You are correct. I have a separate connection for each drive.
If anyone can suggest an inexpensive 8 port that would be great (if they make one in PCI-E), or if yall have any other suggestions, such as an inexpensive 4 external port, or other alternatives I might look into that would be great. I’m a little behind on drive technology, so any suggestions would be great.Playroom Creative
http://www.PlayroomCreative.com -
David Roth weiss
May 30, 2011 at 8:58 pmJohn,
Unfortunately, that one has eight internal ports. The ports would be on the silver thing on the other side if they were external.
David Roth Weiss
Director/Editor/Colorist
David Weiss Productions, Inc.
Los Angeles
https://www.drwfilms.comPOST-PRODUCTION WITHOUT THE USUAL INSANITY ™
Creative COW contributing editor and a forum host of the Business & Marketing and Apple Final Cut Pro forums.
Jerry Alto
May 30, 2011 at 8:59 pmIan- Also check out Firmtek. I know they have a four port.
https://firmtek.stores.yahoo.net/sata2me4e.htmlMacPro 2.93 Quad
FCP7
Sony Z-1
GV-HD700 -
John Pale
May 30, 2011 at 9:29 pmGood catch DRW. Ones with 8 external ports are rare. I actually thought that one had 4 internal and 4 external.
For such cards you can get an inexpensive backplane adapter that connects to the internal ports. You lose a PCI slot, of course, but you can use all the ports, both internal and external.
