Activity › Forums › Adobe After Effects › need 3d block
need 3d block
Posted by Bart_s on June 29, 2007 at 3:31 pmThere used to be an AE project with a block in 3d made up of solids. Anybody know where it might be found?
Michael Zoppo replied 19 years, 2 months ago 3 Members · 3 Replies -
Mike Clasby
June 29, 2007 at 4:12 pmNot a project but here are two ways:
https://forums.creativecow.net/readpost/2/908118?
https://forums.creativecow.net/readpost/2/908121?
Try searching the archives.
Michael Zoppo
June 29, 2007 at 9:15 pmIts not that bad once you get the hang of it, just think of it this way, make a 3d block (requires 6 solids), and then parent all six solids to a null object, so that when the null moves or rotates so does the block, and if you want to go further into detail then you can parent the camera to another null.
