Activity Forums Apple Final Cut Pro Legacy Neat Video plugin crash
  • Neat Video plugin crash
    Posted by Laura Gruszczynski on February 28, 2011 at 4:54 pm
    I am using Neat Video noise remover plugin in FCP7on some Apple pro Res 422HQ footage keyed with Boris Chromakey plugin. I keep getting an error message when i render the footage.
    “Error ! Line: 185
    Function:Malloc
    Error: Neat Video cannot get free memory block from the operating system (or plugin host).
    8294400-byte memory block is requested from 90f4ac53.
    Please make more memory available for application and retry.”
    I then have to Force quit FCP and reopen.
    Any suggestions?
    I am working on a Mac Pro 2.66 Quad, 8GB memory, AJA Kona lhe
    Laura
    Matt Babcock replied 12 years, 2 months ago 6 Members · 6 Replies
  • Michael Gissing
    February 28, 2011 at 11:42 pm
    It sounds like the memory requirements of both plugins may be more that your GPU or FCP can allocate. I would try denoising first and make a new quicktime clip. Then bring that in and try the chromakey.
  • Rafael Amador
    March 1, 2011 at 5:02 am
    First, if you are working with a second monitor, unplug it, so your GPU will be more free.
    If doesn’t works, fallow Michael’s advise and apply the effects in two passes (no problem if you export Unc or Prores).
    rafael
    http://www.nagavideo.com
  • Katherine Sweetman
    October 26, 2011 at 12:13 am
    I had same issue. Had to force quit 🙁
    Just purchased this plug in and not sure how I like it…
  • Rafael Amador
    October 26, 2011 at 2:01 am
    With the details you are giving about your footage/system/etc, is hard to figure out what’s going on.
    rafael
  • Johnathan Throbins
    September 29, 2012 at 8:58 pm
    I found this thread when searching for the same issue. What I did is go into the neat video preferences where it lists processors and GPU cards. I have two GPUs, a GT120 and a GTX285 or some such. The 285 was selected and set to use 100% of the card’s resources. I pulled that back to 80% and it worked fine again.
    The weird part is that it used to work fine with these settings, so I suppose a program I was using today must have left something in the memory of the card and refused to let it get purged to make room for neat video? In any case my solution seems to have worked, at least for now. Hopefully some other searcher will find this useful in the future!
  • Matt Babcock
    July 16, 2014 at 6:17 pm
    I also found this thread while searching on this bug and had a slightly different fix. My system doesn’t have a compatible graphics card so in the preferences I lowered the default 8 cores down to 6 cores and it no longer crashes on me.
