Activity Forums VEGAS Pro Neat Video (noise reduction) plugin
  • Neat Video (noise reduction) plugin
    Posted by Kelly Griffin on February 28, 2020 at 7:14 am
    Do any of you have any experience with the Neat Video plugin (neatvideo.com)?
    I bought it, it’s incredible, but it’s hanging my system at about 30% through a three-minute render.
    I really need this to work… otherwise my client’s not gonna like the footage I shot that was NOT my fault…
    Charles Smiley replied 6 years, 6 months ago 4 Members · 3 Replies
  • Ole Kristiansen
    February 28, 2020 at 8:20 am
    Hi
    What is you system ? You need real computer power to use a plug-in like Neat Video ! Neat Video have to remove noise from 30 or 60 fps ! Also you need to look up for the cpu/gpu settings and test inside Neat Video !
    Best,
    Ole
  • Graham Bernard
    February 28, 2020 at 6:42 pm
    [Kelly Griffin] “Do any of you have any experience with the Neat Video plugin (neatvideo.com)?”
    Yes.
    I have Win10 on an i9 PC. I can render most things out through NV. If you get stuck DB me a short clip and I’ll see what it chokes on. What is:
    1] Your Media
    2] Your Proj Sets.
    3] What are you rendering to?
    Here are two of the NV 5.2 Setup Screens that I run now and then:
    * Grazie
    PC 10 64-bit 64gb * Intel® Core™i9 – 3.3GHz * 40Gb NVIDIA GeForce RTX 2070
    Cameras: Canon XF300 + PowerShot SX60HS Bridge
  • Charles Smiley
    March 3, 2020 at 7:56 pm
    Check every default place Vegas and every plug-in uses to put its “debris”. Get all of them off your C: drive. That has always made life better here -and it keeps junk off my Solid-state C: drive since they have limited capacity. Put junk in your project drive only. Some programs are sneaky with somewhat hidden little junk defaults that put temp files in the C: drive’s folders like “User”.
