Activity › Forums › Apple Final Cut Pro Legacy › NDF to 23.98 to 29.97…possible?
Posted by Beelaster on May 27, 2005 at 4:08 amCan I output a 23.98 timeline, which originated in NDF 30fps, to NTSC 29.97? Will there be a mess?
John Kaley replied 21 years, 3 months ago 3 Members · 2 Replies -
Graeme Nattress
May 27, 2005 at 12:03 pmRemember that NDF is also 29.97fps, in DF, it’s the frame numbers that get dropped, not the frames themselves and NTSC always runs at 29.97fps.
To play a 23.98fps timeline out to NTSC, you’ve got to add 3:2 pulldown. I think some hardware cards might do this, but I’ve not seen it myself, but FCP certainly adds 3:2 when going out over firewire to DV, or if that’s not applicable, I have a little plugin package, Standards Conversion, that will add 3:2 pulldown for you as a render process to convert 23.98fps to 29.97fps NTSC.
Graeme
– http://www.nattress.com – Film Effects for FCP
John Kaley
May 27, 2005 at 12:47 pmMy Aurora IgniterX adds 3:2 pulldown on the fly from 23.976 timelines when monitoring or laying off to Betacam.
