Activity Forums Adobe Premiere Pro Navigating, cutting and snapping on timeline
  • Navigating, cutting and snapping on timeline
    Posted by Alex Rod on March 19, 2013 at 4:22 pm
    Hi –
    When navigating between edits in Final Cut Pro I just used the arrow left/right. This does not work in Premiere. also, on final cut, you can split everything under the header with a keyboard shortcut (opt+V in FCP) but this also seems to not be available in premiere.
    also, my snap option is turned on, but the blade tool does not snap to the play head.
    thank you so much for the help
    been an FPC editor for 12 years and making the transition to PPro
    Kevin Monahan replied 13 years, 5 months ago 3 Members · 2 Replies
  • Angelo Lorenzo
    March 19, 2013 at 5:11 pm
    1. Menu > Edit > Keyboard shortcuts. Next/Prev clip is up and down, you can change this to your liking and even search within keyboard shortcuts to find other things to customize.
    2. This is called add edit Ctrl+K by default (option+K on the Mac I suppose), you can customize this. It will only cut active lanes on the timeline.
    3. The razorblade will cut on the playhead if your cursor is within reasonable distance (3-4 millimeters, so if you get it on the playhead position roughly, Premiere knows what you want). There will be no physical snapping of your cursor.
    Angelo Lorenzo
    Need to encode ProRes on your Windows PC?
    Introducing ProRes Helper, an awesome little app that makes it possible
    Fallen Empire Digital Production Services – Los Angeles
    RED transcoding, on-set DIT, and RED Epic rental services
    Fallen Empire – The Blog
    A blog dedicated to filmmaking, the RED workflow, and DIT tips and tricks
    Can your post production question fit in a tweet? Follow me on Twitter
  • Kevin Monahan
    March 19, 2013 at 7:52 pm
    Correct answers. One thing to number 2: A lot of FCP switchers expect Match Frame and Add Edits to work on selected clips, as well as selected tracks. That is not the case in Premiere Pro, track selection guides both these things. If you want Match Frame and Add Edit to work on selected clips, regardless of track selection, please make a feature request: https://www.adobe.com/go/wish
    Kevin Monahan
    Sr. Content and Community Lead
    Adobe After Effects
    Adobe Premiere Pro
    Adobe Systems, Inc.
    Follow Me on Twitter!
