Activity Forums Adobe After Effects Navigating between layer markers.
  • Navigating between layer markers.
    Posted by Mark Burbery on June 26, 2012 at 8:49 am
    When assigning layer markers by using the * key is there anyway to navigate between these with a shortcut?
    i know that by using the numbered markers “shift+1…” that you can navigate that way, but as im adding quite a high number of markers quickly during ram preview, it would be helpful to be able to quickly go back and forth through them.
    i saw on another post that by pressing the j/k buttons will go through next layer event but it seems to just take me between the beginning and end of my work area.
    Mark Burbery replied 14 years, 2 months ago 43,118 Members · 1 Reply
  • Mark Burbery
    June 26, 2012 at 8:51 am
    Solved –
    Figured out the problem the layer markers had to be on the layer itself rather than the composition.
