Activity Forums Adobe Premiere Pro Navigating better?
  • Navigating better?
    Posted by Sean Tatalovich on September 28, 2007 at 4:35 pm
    Hi guy in the timeline when there are a bunch of clips I sometimes want to go directly to an end or beginning of a clip is there a way to click on the clip and do a shortcut to go to the beginning or end. I usually ahve to scrub and use arrows to find the exact spot.
    Robert Falkowski replied 18 years, 11 months ago 3 Members · 3 Replies
  • Steven L. gotz
    September 28, 2007 at 6:11 pm
    Have you tried using Page Up and Page Down. It will get you to the next cut. In CS3, you can also set up shortcuts in Keyboard Customization to get you to the next cut on a particulr track, if the right track is selected.
  • Sean Tatalovich
    September 28, 2007 at 7:31 pm
    Man your right I totally forgot I was watching a tutorial yesterday and mentioned page up page down. Thanks
  • Robert Falkowski
    September 29, 2007 at 12:17 pm
    Did U try scrubbing while holding “Shift” key?
