Activity Forums Web Design (WordPress, Joomla, etc.) Nav bar arrows.gif do not show up in IE8
  • Nav bar arrows.gif do not show up in IE8
    Posted by Sandie Lawrence on November 4, 2010 at 3:48 pm
    Could someone please take a look at these two pages and see if you can figure out why the nav bar does not show correct formatting or the “arrows.gif” graphic when brought into a 2nd document via a simple JAVA script code?
    The menu works fine when viewed on it’s own here: https://artscouncil.ky.gov/menuAll.htm
    But when the menu is viewed in the 2nd document, the “arrows.gif” images go away and some of the formatting is lost. This only happens in IE8, safari & firefox seem fine.
    Here is the 2nd page document that calls the menu bar via the JAVA Script:
    https://artscouncil.ky.gov/indexmenuArrows.
    Any help would be most appreciated because I’m totally stumped.
    Sandie L
    Sandie Lawrence replied 15 years, 10 months ago 1 Member · 1 Reply
