Activity › Forums › Adobe Illustrator › Natural gas flame vector tutorial
  • Vincent Rosati
    March 14, 2012 at 1:32 am
    I’d create swatches for the colors, then blend ellipses.
    Once the flames are rotated, you can use the Direct Select tool to adjust the flames into the various subtle shapes.
    3852_flamecs4.ai.zip
    The AI file looks like this…
    Here’s a tutorial on how you might rotate the flames.
    https://library.creativecow.net/articles/rosati_vincent/radial_patterns.php
    Vince
    *Please remember to Rate our replies or check Solution if solved. If you get a good idea from the post, consider clicking the Kudos option.
  • Mario Chocooj
    March 14, 2012 at 3:28 am
    Great starting point! Thanks a lot!!
