Activity › Forums › Apple Final Cut Pro Legacy › natress plugins dont appear
Posted by Jason W. miltt on May 16, 2005 at 10:29 amhi:
i am trying several free plugins from nattress but they dont appear in FC.
i copied them to the exact location specified but still they are not there when i run FC.
i have fc 4.5 10.3 and boris and magic bullet installed.
thank you.
Jason W. miltt replied 21 years, 3 months ago 2 Members · 9 Replies -
Graeme Nattress
May 16, 2005 at 11:04 amMost likely cause is a permissions issue. The plugins need to be read and write enabled for all users on the system who use FCP.
Next cause is that you put the plugins in a folder in your library folder, rather than the main library folder on the root of the computer.
Graeme
– http://www.nattress.com – Film Effects for FCP
Graeme Nattress
May 17, 2005 at 2:21 pmYou can check permissions in the finder by using the “get info” menu on an icon. The little window that appears tells you all the permissions of the files. You need to make sure that they’re read / write.
You did unstuff the .sit archive they come in, right, on you Mac with FCP, not another computer?
Graeme
Jason W. miltt
May 17, 2005 at 3:24 pmthey have read and write permission.
i put them in
/Volumes/Macintosh HD/Library/Application Support/Final Cut Pro System Support/Plugins/but when i run FC they are not there.
i am trying the free plugins.
thank you.
Graeme Nattress
May 17, 2005 at 3:27 pmThe plugins, did their icons look like little cubes lego pieces?
Graeme
Jason W. miltt
May 18, 2005 at 4:37 amthey look like cubes in an isometric view with the FC logo on one side.
Graeme Nattress
May 18, 2005 at 11:17 amThat’s good. So we’ve checked the permisions, and we’ve checked they unstuffed right. Are we sure they’re going in the right place – from what you said above it sounds like the right place. I guess in that plugins folder you can see the MB and Boris stuff you have installed. The plugins should just appear in the effects tab as normal. We’ve restarted FCP – I’m at a loss to think of what else we can do. Anyone else got any ideas?
Graeme
Jason W. miltt
May 18, 2005 at 12:20 pmyes, boris and MB are there, g earthquake etc are there too.
the other plugins appear under video filters for example. i have twixtor, boris etc.
anybody has the same problem?
i have 10.3.9 and FC 4.5
Jason W. miltt
June 17, 2005 at 10:26 ami found what it was.
if you copy them using finder it is ok.
i was copying them using mucommander and they didnt appear. strange…if i moved my other plugins to another folder and moved them back they ALL dissapeared from final cut.
using the finder made then come back.
