Activity Forums VEGAS Pro Native support for EX-1?
  • Native support for EX-1?
    Posted by John Bollenbacher on September 17, 2008 at 2:54 pm
    Hey out there,
    Does anyone know if Vegas is planning native support for the EX-1 .mp4 files?
    Right now the workaround is to export them as .mxf files; but that means that if you shoot 1920×1080 – you footage will be changed to the more HDV size of 1440X1080. which is kinda a bummer. CS3 does it native; but I like my Vegas.
    John Bollenbacher
    10engines
    Adam Rose esq. replied 18 years ago 2 Members · 3 Replies
  • Adam Rose esq.
    September 18, 2008 at 8:00 am
    using the browser rewraps them to mp4. That doesn’t resize them to 1440, AFAIK, but then I am an EX1 noob…..
  • John Bollenbacher
    September 18, 2008 at 7:45 pm
    This is from the white paper put out by Sony Creative:
    1. Shoot your video with your XDCAM EX camera.
    2. Transfer your clips from your camera to your computer.
    a. Install the SxS device driver and XDCAM EX Clip Browsing Software.
    b. Connect your camera (or card reader) to your computer with a USB cable.
    c. Your camera will prompt you to “Connect USB Now?” Choose Execute.
    d. In the Clip Browsing Software window, select the clips you want to transfer to your computer.
    e. From the File menu, choose Export, and then choose MXF from the submenu.
    f. In the Export to MXF dialog, choose the folder and file name you want to use to save your clips.
    g. Click Start. The clips are converted to MXF format and copied to your computer.
    3. Drag your captured clips from the Explorer or Project Media window to the timeline to create events.
    4. Edit your project as needed.
    5. Render your project for your destination format.
    So I think the explorer only works with .mxf files. But I’d love to see the documentation on using the xdcam explorer to rewrap the mp4’s if you’ve seen it somewhere.
    Thanks for the post.
    John Bollenbacher
    10engines
  • Adam Rose esq.
    September 18, 2008 at 10:32 pm
    the vegas xdcam explorer doesn’t work with EX footage at all 🙁
