Activity › Forums › Adobe After Effects › Native audio react plugins/presets?
  • Native audio react plugins/presets?
    Posted by Dennis Eriksson on December 14, 2018 at 8:08 am
    Hi, I’m wondering which plugins/presets support adding a sound track to react to? Not using the Keyframe assistant.
    I’ve only found Spectrum and Waveform… are those the only ones you get natively?
    Dennis Eriksson replied 7 years, 9 months ago 1 Member · 1 Reply
  • Dennis Eriksson
    December 14, 2018 at 6:17 pm
    I did say: “Not using the Keyframe assistant”, which is where Convert Audio To Keyframes is… So I already knew about that… and Soundkeys does NOT come with AE, nor is it free, so that doesn’t count just because of that, it also doesn’t count on the fact that it-self can’t be used to like make a waveform, spectrum, plane or whatever, it’s just a glorified “convert to keyframes”…
