Activity Forums Apple Final Cut Pro Legacy Nasty Video Look- how do I eliminate it?!
  • Nasty Video Look- how do I eliminate it?!
    Posted by Mart Twain on September 29, 2005 at 8:55 pm
    I’m working on a short film project, editing on Final Cut Pro. Whilst editing I’ve been relying on my mac’s monitor display and i’ve found that when outputing the film to view elsewhere it looks horribly different!
    The nasty video aesthetic- too sharp, clean unsubtle, evil
    A few weeks back I messed around with all kinds of settings and thought i’d fixed the problem when I outputted a letterboxed version onto dvd- it looked great and as it had done on my monitor screen- but now i’ve de-letterboxed and the problem has returned!!
    The final master is due tomorrow. Somebody please help!!
    cheers, Matt
    Mart Twain replied 20 years, 11 months ago 4 Members · 6 Replies
  • Kevin Monahan
    September 29, 2005 at 11:28 pm
    [endoftheend] “Whilst editing I’ve been relying on my mac’s monitor display and i’ve found that when outputing the film to view elsewhere it looks horribly different!”
    I guess you did not know…pro editors attach an external video monitor as they work to see how their video really looks. The computer monitor is progressive scan and in RGB colorspace. Your video is interlaced and in YUV colorspace. Therefore, what you see on the video monitor is what you get. The computer monitor is not reality. The “look” you describe is actually what your video truly looks like. Video looks like video, right?
    [endoftheend] “A few weeks back I messed around with all kinds of settings and thought i’d fixed the problem when I outputted a letterboxed version onto”
    What kinds of settings? Filters? What?
    If you want your video to look more cinematic, shoot in 24P or use G Film from nattress.com.
    And always work with a video monitor hooked up so you can actually see what you are doing.
    Use a TV if you cannot afford a bonafide production video monitor. 😉
    Kevin Monahan
    Author – Motion Graphics and Effects in Final Cut Pro
    fcpworld.com
  • Graeme Nattress
    September 29, 2005 at 11:58 pm
    Thanks Kevin! I was going to suggest that an Application of Nattress Film Effects will probably do the job – Preset Basic should be perfect!
    Graeme
    http://www.nattress.com – Film Effects and Standards Conversion for FCP
  • Tony
    September 30, 2005 at 1:05 am
    Kevin,
    FCP Filters are only part of the equation. If the team hired to shoot the footage in the first place did not light the project “filmstyle” or put in effort into art direction, motivated lighting, etc etc no magically filter is going to turn the footage into a magically film look. At best the video can be transformed into “faux film” with all the flaws highlighted.
    It only hides the crap it started out as originally.
    In this case please apply the anti crappy video filter found in FCP’s hidden tool chest. It’s next to the experienced crew and editors wanted list.
    Tony Salgado
  • Kevin Monahan
    October 3, 2005 at 1:11 am
    [tony salgado] In this case please apply the anti crappy video filter found in FCP’s hidden tool chest. It’s next to the experienced crew and editors wanted list.”
    Ha ha! Good one Tony. I totally agree with you. As a former lighting guy, it’s so important to light your shot well. Don’t know why this escapes so many people new to the biz.
    I worked on a DV Feature that was shot with a DSR-500 and lit by a Hollywood DP (and this was well before Bullet or Nattress), that looked very cinematic indeed.
    So for a good film look, you have to light is properly first and foremost. Good glass and 3 2/3″ CCDs also greatly improve your look. Top it off with GFilm and you’re good to go!
    Kevin Monahan
    fcpworld.com
  • Mart Twain
    October 3, 2005 at 11:32 am
    Well, I totally agree with you. You can’t cover up bad lighting and photography with post-production effects, but the point is that the image itself is perfect, the problem occurs when the image is in motion.
    Applying the nattress did the trick, but also just applying a small amount of motion blur gave the desired effect to the movement.
    A very experienced DOP worked on this film, who did an amazing job working on a dsr 570 and a limited amount of lighting. But film is about images in motion and this film in particular is about movement and physicallity, so the harsh blunt nature of DV did not fit it. Had we had a bigger budget we would have shot on film, but we didn’t and you can’t pretend that having great photography and lighting work is going to cover up the fact that DV is not a medium best suited to cinema.
    Having said that, it was very easy to eliminate ‘the nasty video look’ once I worked out how and all that took was a couple of dumb and naive sounding posts on an internet forum! Problem solved
    cheers, matt
  • Mart Twain
    cheers, matt
