Activity › Forums › VEGAS Pro › Nasty flashes of wrong images when rendering in mp4
  • Nasty flashes of wrong images when rendering in mp4
    Posted by Riccardo Leone on May 3, 2013 at 8:51 am
    Hi there guys! Here I am for another question…
    I rendered my project a few times already in Vegas 12; format mp4. Basically, I’ve been following Vimeo compression guidelines. However a weird thing happens: in the final product I get these random flashes of distorted images (from the film) that are not supposed to be there. For example, during the titles I get a flash of an image that should come like 30 seconds after; at mid film I get a flash of the title…
    Further information: this doesn’t happen when rendering in other formats (.avi for instance). Also, the problem never occured before (I perfectly rendered another project yesterday morning; also, I rendered the some project some time ago – just a rough cut – and it was OK). When I re-render, I get different flashes in different moments of the film. I tried to restart Vegas as well as to rebbot the computer, but with no results.
    Thank you all for the help!
    Norman Black replied 13 years, 4 months ago 3 Members · 4 Replies
  • Steve Rhoden
    May 3, 2013 at 8:55 am
    Did you try disabling the GPU to see if thats what causing the issue?
    Steve Rhoden
    (Cow Leader)
    Film Editor & Compositor.
    Filmex Creative Media.
    https://www.facebook.com/FilmexCreativeMedia
    1-876-832-4956
  • Riccardo Leone
    May 3, 2013 at 10:11 am
    ..no I didn’t. Thank you for the hint. Gonna try and I’ll let you know!
  • Riccardo Leone
    May 3, 2013 at 10:35 am
    Thanks, that is definitely the problem. The new output is perfect.
    So what should I do? And why that doesn’t happen in other projects?
  • Norman Black
    May 3, 2013 at 7:18 pm
    Either leave GPU off permanently, or turn it off as needed when you have an issue.
    Vegas is not 100% bad with GPU, nor is it 100% good. It is somewhere in the middle. Unfortunately that leaves people in limbo with your question. What do I do? No perfect answer.
