Activity › Forums › Apple Final Cut Pro › NASty Disk Images
NASty Disk Images
Posted by John Davidson on August 3, 2012 at 7:28 pmJust got our first NAS going yesterday and trying to get our events into sparse disk images.
When you guys move events to a sparse disk image, does FCPX always give you the ‘out of space’ warning? I made a 20 Gig sparse image on the NAS for an event that was only 40 megs, moved the event via fcpx, and still got the disk full warning from FCPX and could either continue or stop file transfer. Plus, the image is 20 gigs, but with nothing in it but the 40 megs we wanted.
It seems to work, the image mounts on any machine, and nothing seems lost. Is this just a bug?
JDJohn Davidson | President / Creative Director | Magic Feather Inc.
John Davidson replied 14 years, 1 month ago 4 Members · 9 Replies -
Jason Jenkins
August 3, 2012 at 10:48 pmI’ve always created the disk image first, then the event. So I’m no help there. I am interested in how you set up your NAS, though! Are you using a Pegasus?
Jason Jenkins
Flowmotion Media
Video production… with style!Check out my Mormon.org profile.
John Davidson
August 3, 2012 at 11:19 pmIt’s a Mac-Mini FrankenNAS! Craziest thing yet and it totally works!
The ingredients are as follows:
1 Mac Mini server with as much RAM as you can get (I got 8 but need to upgrade it to 16).
1 Areca 1882x with Thunderbolt Driver updates
1 Proavio 8MS with 8x3Tb Hitachi Deskstar Drives
1 Small Tree 6 Port Ethernet card
1 UPS w battery backup
1 Sonnet Echo Express PCI to Thunderbolt BoxAll systems are running Mountain Lion. I wanted the Magma box but they’re backordered for 6-8 weeks so I got the Sonnet.
Installed the Small Tree gigabit ethernet drivers. Installed the Areca drivers and thunderbolt update. Took the Areca out of a mac pro edit suite as well as the ProAvio box. Plugged them in. The system worked. 600MB/s up and down on the AJA test, although the test gives some odd outputs from time to time, it’s mostly consistent.
Really can’t say enough great things about Matt, Steve, and Chris at Small Tree for their help. It takes a little settings work to get this thing running correctly, but it’s good. We’re editing off of the media drives and I’m still pinching myself about it. We digitized HDCam using Blackmagic Media Express over ethernet. The fact that we were able to recycle some of the hardware elements we already have like the Areca and ProAvio make this an affordable option. If you’re buying all new equipment it might be smarter to to get a ThunderNet or something similar.
We also have a Promise Pegasus that would have eliminated the need for the Areca/Proavio box, but our storage is much larger than what the 6 drive Pegasus can offer.
This is a great interim solution for us in the meantime to stream video to four separate rooms. Just sharing after effects projects and media is fantastic. Apparently this Mac Mini Server can do a whole lot more. I’m tempted to get another one and start hosting our own email and contact sharing info.
One other thing, the two Mac Pros we have are using both ethernet plugs. One port for external internet and another for the NAS. I’m pickled tink!
John Davidson
August 4, 2012 at 1:17 amFor archival purposes or migrating to a NAS, I think this is an example of when it would be acceptable to create the disk image and then use finder to copy projects and events over. When making the image first and then the event as you described, FCPX is fine to manage it. Just doing a test seems to confirm this. Not really sure why FCPX doesn’t like it.
Jason Jenkins
August 4, 2012 at 1:33 amThat’s pretty sweet! If I have only two macs (one plugged into a Pegasus R6) can I just ethernet network them together and share the storage? My Macbook Pro only has one ethernet jack, but the wi-fi is so fast, I don’t really need it for internet. Thinking about getting an iMac to add to the configuration.
Jason Jenkins
Flowmotion Media
John Davidson
August 4, 2012 at 7:32 amYes, you can work that way but if you’re accessing the same media at the same time you will get dropped frames. The small tree card eliminates that issue. However, the server machine cannot be an editing machine. Its a bit confusing at first, honestly.
Jeremy Garchow
August 4, 2012 at 2:14 pmThis makes me nervous.
Be careful and let us know how it goes in the long term.
Andreas Kiel
August 4, 2012 at 4:05 pmI don’t have a NAS but just an old spare machine connected thru ethernet which is used to backup some customer test projects.
The way it works here is to create a sparse(bundle) with my
own little app (https://www.spherico.com/filmtools/createDiskImage/CreateDiskImage.dmg) and move the stuff.
I never got an “out of space” error except the sparse disk image really was to small.
Might be that swapping files need a bit more virtual memory on this virtual drive. So maybe creating a 100 gig sparse disk image could solve the problem.-Andreas
Spherico
https://www.spherico.com/filmtools -
John Davidson
August 4, 2012 at 5:39 pmI should clarify I’m copying and deleting from the source which prevents duplicate FCPX identifiers from confusing the program. This essentially does the same thing as Event Manager X. So far so good.
John Davidson
August 4, 2012 at 5:39 pmI’ll check that out!
