Activity › Forums › Adobe After Effects › nasty bit of aliasing – any tips on removing it?
  • nasty bit of aliasing – any tips on removing it?
    Posted by Dylan Hargreaves on December 28, 2012 at 9:18 pm
    Hey folks,
    Please take a look at the attached still. Notice the light behind the presenter: there’s a nasty bit of red aliasing off its left edge.
    The footage is AVCHD natively edited in Premiere Pro and sent to AE for grading. If I can’t remove it from the original footage, might transcoding the footage using an HQ compressor such as 5DtoRGB get rid of it?
    Thanks in advance!
    D
    Dylan Hargreaves replied 13 years, 9 months ago 2 Members · 3 Replies
  • Dylan Hargreaves
    December 28, 2012 at 11:33 pm
    It was actually an FS700 Dave!
    I do have a bit of time, but if it means removing it frame by frame I’m not sure the budget quite justifies it.
    It’s on a tracking shot, but I’m wondering if a cheeky bit of photoshop work might suffice…
  • Angelo Lorenzo
    December 29, 2012 at 1:24 am
    Its hard to tell from the stills, but the channels all look a little fried. I would try tracking the object and applying a localized channel blur.
    5DtoRGB may help, as I would also assume any conversion with FFMPEG/FFMBC as they bypass Apple’s Quicktime elements which seem to chew up video.
    Angelo Lorenzo
    Need to encode ProRes on your Windows PC?
    Introducing ProRes Helper, an awesome little app that makes it possible
    Fallen Empire Digital Production Services – Los Angeles
    RED transcoding, on-set DIT, and RED Epic rental services
    Fallen Empire – The Blog
    A blog dedicated to filmmaking, the RED workflow, and DIT tips and tricks
  • Dylan Hargreaves
    December 29, 2012 at 12:18 pm
    Thanks Angelo, will give it a try!
