Activity Forums Adobe After Effects Naming output files in AME on export from AE
  • Naming output files in AME on export from AE
    Posted by Kirill Skorodelov on November 5, 2015 at 12:19 pm
    Hi, there is a question on the way AME names output files if an AEP is added to AME queue via watch folder.
    AME 2014 gives an output file the name of an AEP and this suits my needs.
    But AME 2015 gives a comp name which will be rendered to an output file.
    So the question is – is it possible to configure AME 2015 output files naming rule so it gives it a name of an AEP which is added via watch folder (as it is in AME 2015) but not a to-be-rendered comp name.
    Thanks a lot in advance for any help.
    Kirill Skorodelov replied 10 years ago 2 Members · 2 Replies
  • Dan Fraticiu
    September 1, 2016 at 3:46 pm
    Hey Kirill,
    any chance you figured out a way to get this behaviour?
    Thanks.
  • Kirill Skorodelov
    September 1, 2016 at 9:28 pm
    No, the only way is to rename the active comp after the project with a script
