Activity Forums Maxon Cinema 4D Naming object buffers?
  • Naming object buffers?
    Posted by Brian Murphy on September 10, 2009 at 4:53 pm
    Hey guys,
    Is it not possible to name the object buffers in the multipass window so that when my buffers are rendered out, they already have the desired name in the filename? Or do I have to change the filename after rendering? I have a lot of object buffers and it would be wonderful to set the filename before rendering.
    Brian
    Greg C neumayer replied 6 years, 9 months ago 5 Members · 4 Replies
  • Chris Martin
    September 18, 2009 at 10:40 am
    I did a video tutorial on object buffers https://www.kreativedomain.com/?p=1
    if this is what you are referring to then the answer is not at this time….that is something that I think everyone would like to see in upcoming versions.
    Regards,
    Chris Martin
    http://www.kreativedomain.com
  • Greg Neumayer
    June 27, 2014 at 5:03 pm
    Well, 5 years later, I’m asking the same question.
    Chris, your link is broken. Can either of you answer this question? I’d like C4D to spit out named object buffers. Can I?
    Greg
    Antifreeze Design
    https://www.antifreezedesign.com
  • Andrew Foresman
    November 12, 2019 at 8:27 pm
    Greg, do you have the answers yet?
  • Greg C neumayer
    November 12, 2019 at 9:57 pm
    I think the answer is “kinda”. (R19 Broadcast)
    The compositing tag on my object makes me assign the object to a numbered buffer.
    However, in my multi-pass Save options, when I add an Object Buffer I AM allowed to rename it.
    When rendering, it will use your render-setting-assigned-name for the Object Buffer IF you check the box “User Defined Layer Name” (e.g. “…_GregsBuffer_…”)
    Leaving this unchecked will default to appending it with the numerical value of the Object Buffer used in your Compositing Tag (e.g. “…_object_2…”) .
    Hope it helps!
    -Greg
