Activity › Forums › Panasonic Cameras › naming clips
  • naming clips
    Posted by Gerret Warner on May 22, 2010 at 1:11 pm
    I have a new project for which I need to name clips with descriptive titles rather than Panasonic’s numbering system, while–at the same time–ensuring that my FCP project will allow me to reconnect sometime in the future. MXF4mac sounds like a solution but it costs too much.
    Is there an alternative? If I simply rename clips names in Log and Transfer those names won’t be in the Metadata of the MXF file. Will they reconnect once I’ve trashed my Quicktime files?
    I’ve tested P2CMS by ingesting MXF files, renaming user clip names in “metadata upload” by all that does is create text files to save with the card? The new data doesn’t show up in either P2CMS or in FCP?
    Hope someone’s got a suggestion besides MXF4mac.
    GW
    Gerret Warner replied 16 years, 4 months ago 4 Members · 14 Replies
  • 14 Replies
  • Noah Kadner
    May 22, 2010 at 2:20 pm
    Just rename them in your FCP bins- use one of the alternate logging columns and you won’t break anything.
    Noah
    Check out my book: RED: The Ultimate Guide to Using the Revolutionary Camera!
    Unlock the secrets of 24p, HD and Final Cut Studio with Call Box Training. Featuring the Sony EX1 Guidebook, Panasonic HVX200, Canon EOS 5D Mark II and Canon 7D.
    Watch Formosa- My indie movie shot with the SDX900 and finished with Final Cut Studio.
  • Gerret Warner
    May 22, 2010 at 6:29 pm
    Thanks for the tip, Noah, but my new names will be in the FCP project only, not saved to the MXF files, true?
    (Also, for the record, I thought that you could rename P2 files names in the name column because Panasonic has a longer numeric file that maintains the identity beyond the default numeric name that comes in via Log and transfer… or did I dream this?
    Thanks again,
    GW
  • Noah Kadner
    May 22, 2010 at 8:00 pm
    That is correct. If you rename the actual media you’ll break media management- don’t do it. 🙂
    Noah
  • Jeremy Garchow
    May 23, 2010 at 2:40 am
    P2CMS will rename user clip name files and save it back to the XML, but the process is very long, slow and boring. Right click on a clip and choose property from the drop down, then modify the user clip name. You have to do each clip, one at a time. It can be arduous.
    I know you don’t want to hear this, but P2 Flow from MXF4mac is the most elegant way of doing this. It is not the cheapest software, but it gets it done very well. It will pay for itself over time saved with one or two jobs, no doubt. Batch naming and auto numbering is possible.
    Here’s a down and dirty sample I made of P2Flow/MXF Import and how fast it works with P2 MXF media:
    https://reels.creativecow.net/film/p2-flow-example
    I had both AVC-I 100 and DVCPro HD in this project.
    Jeremy
  • Gerret Warner
    May 23, 2010 at 1:51 pm
    Thanks Noah and Jeremy,
    You’ve confirmed my experience. P2CMS is free but it’s almost indecipherable… and slow.
    Is P2 Flow all I need to rename user clips without breaking the connection between MXF and FCP and to edit MXF files directly without creating QT files? Going to MXF4mac’s site made me wonder whether you need MXF Capture as well.
    GW
  • Jeremy Garchow
    May 23, 2010 at 2:32 pm
    You don’t need Capture.
    I recommend getting the P2Flow and MXF Import bundle. P2Flow edits metadata, MXF Import allows the previwing of files and subsequent import to FCP. You can wrtie and ask for a demo.
  • Shane Ross
    May 24, 2010 at 1:23 am
    You can rename the clips in the L&T interface, or import them and rename the clips, and then use the RENAME feature to rename the media files to match the clips. FCP will STILL be able to relink to the original MXF files and reimport if the media is lost. Because the 32 character GLOBAL ID number that is embedded in the metadata is carried over to the QT file.
    I have tested this…renaming, deleting the media, reimporting. Works fine. Pretty flawless really. Slicker than Avid really.
    Shane
  • Jeremy Garchow
    May 24, 2010 at 1:52 am
    Yeah, that works too, but all that user clip name data then lives in the FCP project only.
    Using p2 flow, all the metadata stays with the MXF media for ever.
  • Gerret Warner
    May 24, 2010 at 12:05 pm
    As I thought, Shane.
    GW
  • Gerret Warner
    May 24, 2010 at 12:13 pm
    It looks as if MXF import allows you to edit MXF inside FCP without taking up hard drive space with Quicktimes in Capture Scratch. Does it work?
    GW
