Activity › Forums › Apple Final Cut Pro Legacy › ‘n’ command messing with me!
Posted by Bill Thomas on August 14, 2008 at 4:15 amOK, I love the ‘n’ command to snap to edges of clips, but why is it that I can hit ‘n’ and it will snap once. Then when I try to snap again, it’s deactivated and I have to hit ‘n’ again!!
Is there a setting I’m missing? I though when I turned it on, it would stay on till I turned it off.
Any help would be appreciated!
Bill
Darren Andrews replied 18 years ago 5 Members · 7 Replies -
Colin Mcquillan
August 14, 2008 at 5:34 amWhen they first changed this it drove me NUTS,
But then I got used to it and now I love this feature.I can’t remember which update brought this about, but nowadays if you have a clip selected and hit ‘n’ to turn snapping either off or on, it will only remain in the newly selected state until you let go of the clip you’re dragging.
To get it to stay in the mode you want, you need to hit ‘n’ before you grab the clip you want to move.
Colin McQuillan
Van. B.C. -
Bill Thomas
August 14, 2008 at 12:37 pmSo I should be hitting ‘n’ while I’m dragging the clip? (like drag and drop)? Then it’ll stay that way?
Tom Wolsky
August 14, 2008 at 1:02 pmNo, the other way around. If you press n while you’re dragging the snapping function will revert to whatever state it was in before when you release the clip. If you want the snapping function to be fixed in one state you have to press the n key before you grab the clip to drag it.
All the best,
Tom
Class on Demand DVDs “Complete Training for FCP6,” “Basic Training for FCS2” and “Final Cut Express Made Easy”
Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 4 Editing Workshop” -
Tom Wolsky
August 14, 2008 at 1:03 pmNo, the other way around. If you press n while you’re dragging the snapping function will revert to whatever state it was in before when you release the clip. If you want the snapping function to be fixed in one state you have to press the n key before you grab the clip to drag it.
I still dislike the behavior, but at least the split edit bug it caused was fixed.
All the best,
Tom
Darren Andrews
September 15, 2008 at 12:29 pmDoes anyone actually like this feature? I spend more time on the N key now than I ever did. It used to be hit N, snapping turns on or off then stays that way until you hit N again. Now I start dragging something, realize snapping is off, hit N to turn snapping on, drop what I was dragging, pick something up, snapping is now off, have to hit N again and so on. It’s annoying, and falls into the “if it ain’t broke, don’t fix it” category.
Come on, Apple, were you bored, did you have nothing better to do? Here’s a thought… Fix some of the bugs that have been around since version 1 instead of messing with the stuff that works.
